Date/Time: Sat, 21 Dec 2024 17:03:39 +0000
syncronise sim trades across charts
View Count: 1161
[2014-12-17 11:10:09] |
User96105 - Posts: 113 |
Hi, I have a chartbook with several charts all the same instrument (YM). But my sim account balance/records do not show the same on all charts. How do I synchronize these? Thanks
[2014-12-18 11:53:13] |
I've just flattened two long contracts on one chart, which on another chart the effect has been to flattened one contract and taken me short another contract. So very odd stuff going on. Also I have noticed in the past that, where I have two or more contracts on, that the stop/limit orders to close out one contract often act to close the other, which is frustrating. Is there some setup that I have not carried out correctly on my charts? My charts show the associations of the target and stops for the bracket orders, but not the association with the specific order itself, which can be confusing with more than one contract in place (an average of the positions is shown rather than the position of each order). Is it possible to change this to show each separate order with association lines? Thanks, |
[2014-12-19 10:16:23] |
Refer to this section here: http://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#DisplayingOrdersPositionFillsOtherChart I've just flattened two long contracts on one chart, which on another chart the effect has been to flattened one contract and taken me short another contract. So very odd stuff going on.
Make sure you have Chart >> Chart Settings >> Load Order Fills for Current Day Only unchecked. And select Chart >> Reload. And take note of this information here:http://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#DisplayingOrdersPositionFillsOtherChart Also I have noticed in the past that, where I have two or more contracts on, that the stop/limit orders to close out one contract often act to close the other, which is frustrating. Is there some setup that I have not carried out correctly on my charts? We do not understand what you mean by this.My charts show the associations of the target and stops for the bracket orders, but not the association with the specific order itself, which can be confusing with more than one contract in place (an average of the positions is shown rather than the position of each order). Is it possible to change this to show each separate order with association lines?
Sierra Chart is not designed for this at all and there is 0% chance of this.
[2014-12-19 10:28:04] |
Update: one of my charts ~ 120min YM shows a high of 17980 on 5 Dec, but my 15000 Tick (Trade) chart is showing a high of 17910. Both chart settings are exactly the same other than the bar period, including automatic rollover. Both charts seem to be using the same data file (Date range 2014-10-01 to 2014-12-19). I have reloaded the charts, deleted/downloaded the date for both charts, and restarted SierraChart. Still the same. You comments appreciated please |
[2014-12-19 10:31:43] |
You need to determine what contract month you are looking at. Enable Chart >> Show Rollover Dates. For more information, refer to the Continuous Futures Contract documentation page. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-19 10:32:00
[2014-12-19 10:56:20] |
Great, thanks ~ one chart was set to Back Adjusted, and the other wasn't.
[2014-12-19 11:05:51] |
Make sure you have Chart >> Chart Settings >> Load Order Fills for Current Day Only unchecked. And select Chart >> Reload. And take note of this information here: http://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#DisplayingOrdersPositionFillsOtherChart Great, thanks, this was checked on some of my charts which was causing confusion |
