Date/Time: Mon, 05 Oct 2026 06:09:52 +0000
Parallel Rays Tool is Broken
View Count: 1655
| [2014-12-16 02:50:21] |
| User40877 - Posts: 16 |
I'm on version 1217 and the parallel rays tool is not working. When drawing the 3 points on the chart the lines are not appearing on the chart. After releasing the tool the lines do not appear on the chart, either.
| [2014-12-16 03:05:52] |
We do not see a problem with this drawing tool. Possibly there are out of order timestamps in the chart. Re-download the data with Edit >Delete All Data and Download. Also check the color settings for the drawing tool through Global Settings >> Tool Configs >> Parallel Rays. Make sure the colors are different than the background color. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-16 03:07:28
| [2014-12-16 03:35:10] |
Deleted the data and checked color settings, still have the problem. Here's a video I made demonstrating the issue: http://goo.gl/sS3Mor
| [2014-12-16 09:58:30] |
We do see the problem after some additional testing. It will be corrected later today.
| [2014-12-18 20:16:07] |
Just so you know, the latest prerelease, 1219, has this definitely resolved. We were not sure if the problem resolution made it out in 1218, but 1219 has it.
| [2014-12-18 20:19:25] |
Ok, thanks. I'll wait for the actual release.
| [2014-12-18 20:50:50] |
The actual release has been made. Nothing to wait around for. It would serve no purpose.
| [2014-12-18 21:52:40] |
I get this message when I try to upgrade: There is no new version available. Thank you. | 2014-12-18 13:51:22 * |
| [2014-12-18 22:26:10] |
Use Help >> Download Prerelease. There is no need to be concerned about the prerelease. It is completely stable.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-18 22:26:26
| [2014-12-18 22:45:11] |
OK...just installed the prerelease and the tool is working correctly.
