Date/Time: Thu, 03 Apr 2025 20:25:37 +0000
[Locked] - Recommended New Text Editor
View Count: 8201
[2014-12-07 03:13:58] |
For a long time now, we have been disappointed with the Notepad ++ text editor we supply with Sierra Chart for editing ACSIL source code files. It has proven to have stability issues at least in the way that we have been using it. It regularly abnormally shuts down and is a huge annoyance and causes lost work. It has been such a problem, it got to a point where it was fearful even using it, just waiting for the next time it would crash. We no longer use it and this is the recommended editor we now use: http://www.jedit.org/ We will look at supplying this one with Sierra Chart as long as it is not too large. Once you install this editor, you can set Sierra Chart to use it through Analysis >> Build Custom Studies DLL >> Select Editor. It is a good full-featured editor. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-07 03:16:19
[2015-02-17 16:10:37] |
shrubberyMoves - Posts: 2 |
Hello, two questions from a new user: 1) is it possible, and is there any downside, to using the free VC++ Express 2010 which is somewhat familiar to me? 2) for jedit, are there recommended plug-ins for use with ACSIL? |
[2015-02-17 17:36:16] |
1. This will be fine. 2. Nothing that we are aware of. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-01 19:25:27] |
mbarbhaya - Posts: 37 |
Dear Support, Please help me with instruction on how I can have some better editor integrated with Sierra charts |
[2023-01-01 20:56:51] |
Sierra_Chart Engineering - Posts: 19064 |
This is a very old thread and is out of date.
