Date/Time: Sat, 21 Dec 2024 17:54:31 +0000
Connect
View Count: 955
[2014-11-21 16:02:14]
User534242 - Posts: 1
Today , I can not connect to the server ... so I had no problem yesterday and The preceding days.
Log copy:
CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2014-11-21 17:01:28
CTS FIX - Firm: Dorman | 2014-11-21 17:01:28
CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2014-11-21 17:01:28
CTS FIX socket (900) | Connected. | 2014-11-21 17:01:28
CTS FIX socket (900) | Starting SSL connection. | 2014-11-21 17:01:28
CTS FIX socket (900) | SSL connection established. | 2014-11-21 17:01:29
CTS FIX: Sending the Logon message. | 2014-11-21 17:01:29
CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2014-11-21 17:01:29
CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-11-21 17:01:29
CTS FIX socket (900) | SSL shutdown indicates not able to send 'close notify'. | 2014-11-21 17:01:29
CTS FIX socket (900) | SSL has been shut down. | 2014-11-21 17:01:29
CTS FIX socket (900) | SSL object has been freed. SSL state is now disconnected. | 2014-11-21 17:01:29
CTS FIX socket (900) | Shutdown and closed. | 2014-11-21 17:01:29
CTS FIX: Logged out and disconnected. | 2014-11-21 17:01:29
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-11-21 17:01:29
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-11-21 17:01:29
CTS FIX: Disconnected. | 2014-11-21 17:01:29
Will reconnect to the server in 3.0 minutes Select 'File >> Disconnect' to prevent further connection attempts. | 2014-11-21 17:01:29
[2014-11-21 17:59:49]
This is the relevant message:
Refer to step 15 here about this:
https://www.sierrachart.com/index.php?page=doc/CTS_T4.php#SetupInstructions
Also make sure that the correct Service is set in Global Settings >> Data/Trade Service Settings.
This log indicates you are connecting to the CTS T4 system.
Date Time Of Last Edit: 2014-11-21 18:01:49
