Date/Time: Sat, 04 May 2024 21:18:12 +0000
Finish delta %
View Count: 2686
[2013-05-16 18:13:21] |
TradingMarketProfile - Posts: 120 |
Hello, First, thanks to added finish delta in numbers bars calculated values Is it to much to ask you if it's possible for you to add Finish delta % it will be easyer to see the result Thanks |
[2013-05-16 18:18:04] |
How is the percentage calculated?
[2013-05-16 19:10:21] |
you know the finish delta is the pullback from the highest between the max or min delta so for exemple if max delta is 200 and finish delta is -50 the percentage of the pullback should be 25% see the chart if you want to see the numbers http://www.sierrachart.com/image.php?l=136873124054.png |
[2013-05-17 17:46:46] |
Hello, Any news ? |
[2013-05-18 00:41:23] |
We will see about adding this.
[2013-05-18 07:21:02] |
ok thanks
[2013-05-18 19:25:04] |
This has been added to the latest release.
[2022-07-20 08:30:48] |
Betoune45 - Posts: 4 |
hello, concerning the % finish, would it be possible, for optimal reading quality, to round the % finish to the lower or upper unit depending on whether it is above or below 0.5%. Indeed, with 2 decimals (which do not provide much more information), the ballast is not at the top. Thanks |
