Date/Time: Tue, 04 Nov 2025 05:59:42 +0000
[User Discussion] - Feature Request: Fibonacci Spiral
View Count: 1870
|   [2014-11-13 20:03:49]     |
| U.Sohyur - Posts: 21 |
                Please add this feature if it is feasible to do so. This is probably the only drawing feature (a very useful one, might I add) that is not available. I know of one other current Sierra Chart user who would like this feature as well. Here is an example of Fib spiral on another platform, along with the associated properties. http://www.screencast.com/t/or3qp9103F http://www.screencast.com/t/qI7Pu7XWn Thanks for the consideration.  |
|   [2014-11-14 17:50:33]     |
                We will look into this.
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2015-02-02 07:09:40]     |
| User69487 - Posts: 21 |
                Bump, this would be quite useful.
|   [2015-02-05 04:31:20]     |
                It is not likely this is going to be added anytime soon. We recommend using another program if you have a need for this.
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-02-05 04:31:52
|   [2015-02-05 06:23:29]     |
| dem_z - Posts: 14 |
                FYI - I don't think Think or Swim calculates it properly.
