Date/Time: Tue, 04 Nov 2025 10:51:00 +0000
[User Discussion] - To add the Lock Drawing command to the Chart Drawing Shortcut Menu, refer to Customizing Chart D
View Count: 1819
|   [2014-11-01 01:17:32]     |
| superdoug3 - Posts: 40 |
                is Lock Drawing still a command available for Chart Drawing menu ? I use Erase all text and erase all drawings often, Lock Drawing would allow me to lock my current chart and erase all other text and drawings  |
|   [2014-11-04 17:03:25]     |
                Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#CustomizingCDMenu We recommend referring to the documentation before posting here. Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2014-11-04 17:31:19]     |
                I did check documentation first.    I got confused between 'chart menu' and 'chart drawing menu' - my objective was to erase all text and drawings except for current day.    Doesn't seem possible.   thank-you anyways. (P.S. I know thank you isn't necessary, just clarifying that I was confused, not lazy)
|   [2021-02-12 00:30:19]     |
| whats1thingnow - Posts: 407 |
                is there a keyboard shortcut for 'lock drawing'? couldn't find it if it's there - thanks for the help  |
|   [2021-02-12 15:04:33]     |
| John - SC Support - Posts: 42737 |
                There is not a keyboard shortcut, as we would need to ask which drawing you would want to lock, which defeats the purpose. You can use the Right-Click shortcut options to lock the drawing, which may be the fastest way. For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
