Date/Time: Thu, 28 Nov 2024 00:29:05 +0000
AGN changed clearing firms and now am unable to get data
View Count: 959
[2014-10-28 21:26:22] |
MMX - Posts: 119 |
AGN switched from Vision to Phillips Capital Friday evening, I was switched from Vision to Phillips today. My data/trade service with Vision was CTS, my data/trade service with Phillips is CTS. In the SC Data/Trade Service Settings window I have entered my new username and new password and changed the Firm name to Phillip (they said Phillip, not Phillips). I'm using 10443 for the HTTP SSl Proxy Port as per the CTS info in the SC help section. I have also checked Enable Fix Logging. When I start up SC, the message log does not appear as it normally does and I'm not receiving new data. What am I overlooking?
[2014-10-28 21:50:40] |
Provide a copy of the Message Log, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-10-28 21:57:25] |
MMX - Posts: 119 |
There is no message log, it just doesn't come up.
[2014-10-28 22:06:32] |
MMX - Posts: 119 |
My error. The message log doesn't pop up like it always does but you can pull it up manually, and there is current info in the message log, just give me a few minutes to read the link that you posted above and then I'll send the message log.
[2014-10-28 22:10:10] |
MMX - Posts: 119 |
Software version: 1202 | 2014-10-28 16:33:13 Usage end date: 2015-01-01 | 2014-10-28 16:33:13 Enabled for: Advanced Features. | 2014-10-28 16:33:13 Enabled for: Sierra Chart Historical Data Service. | 2014-10-28 16:33:13 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-10-28 16:33:13 Active service: CTS T4 FIX | 2014-10-28 16:33:13 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-10-28 16:33:13 2014-10-28 16:33:13 Local computer clock time | 2014-10-28 16:33:13 2014-10-28 21:33:13 GMT time | 2014-10-28 16:33:13 2014-10-28 16:33:13 Time zone adjusted time | 2014-10-28 16:33:13 Time difference to server time: 5 seconds. | 2014-10-28 16:33:13 Program path: C:\SierraChart\ | 2014-10-28 16:33:13 Data Files path: C:\SierraChart\Data\ | 2014-10-28 16:33:13 OS Version Number: 6.1 | 2014-10-28 16:33:13 Locale Information: English_United States.1252 | 2014-10-28 16:33:13 Checking for new symbol settings for cts | 2014-10-28 16:33:13 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 88.198.13.175 | 2014-10-28 16:33:13 HTTP connection to www.sierrachart.com:80 (1436) | Connected. | 2014-10-28 16:33:13 Symbol settings are up-to-date for cts | 2014-10-28 16:33:13 Files to Open on Start up | Opening file: Index Book 1-2.5-5.cht | 2014-10-28 16:33:16 Date rule based rollover from YMH12 to next contract occurs at 2012-03-08. | 2014-10-28 16:33:17 Date rule based rollover from YMM12 to next contract occurs at 2012-06-07. | 2014-10-28 16:33:17 Date rule based rollover from YMU12 to next contract occurs at 2012-09-13. | 2014-10-28 16:33:17 Date rule based rollover from YMZ12 to next contract occurs at 2012-12-13. | 2014-10-28 16:33:17 Date rule based rollover from YMH13 to next contract occurs at 2013-03-07. | 2014-10-28 16:33:17 Date rule based rollover from YMM13 to next contract occurs at 2013-06-13. | 2014-10-28 16:33:17 Date rule based rollover from YMU13 to next contract occurs at 2013-09-12. | 2014-10-28 16:33:17 Date rule based rollover from YMZ13 to next contract occurs at 2013-12-12. | 2014-10-28 16:33:17 Date rule based rollover from YMH14 to next contract occurs at 2014-03-13. | 2014-10-28 16:33:17 Date rule based rollover from YMM14 to next contract occurs at 2014-06-12. | 2014-10-28 16:33:17 Date rule based rollover from YMU14 to next contract occurs at 2014-09-11. | 2014-10-28 16:33:17 Date rule based rollover from YMZ14 to next contract occurs at 2014-12-11. | 2014-10-28 16:33:17 Checking Daily data file for symbol YMH12 for the date range from 2011-12-08 to 2012-03-08. | 2014-10-28 16:33:17 Checking Daily data file for symbol YMM12 for the date range from 2012-03-08 to 2012-06-07. | 2014-10-28 16:33:17 Checking Daily data file for symbol YMU12 for the date range from 2012-06-07 to 2012-09-13. | 2014-10-28 16:33:17 Checking Daily data file for symbol YMZ12 for the date range from 2012-09-13 to 2012-12-13. | 2014-10-28 16:33:17 Checking Daily data file for symbol YMH13 for the date range from 2012-12-13 to 2013-03-07. | 2014-10-28 16:33:17 Checking Daily data file for symbol YMM13 for the date range from 2013-03-07 to 2013-06-13. | 2014-10-28 16:33:17 Checking Daily data file for symbol YMU13 for the date range from 2013-06-13 to 2013-09-12. | 2014-10-28 16:33:17 Checking Daily data file for symbol YMZ13 for the date range from 2013-09-12 to 2013-12-12. | 2014-10-28 16:33:17 Checking Daily data file for symbol YMH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-10-28 16:33:17 Checking Daily data file for symbol YMM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-10-28 16:33:17 Checking Daily data file for symbol YMU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-10-28 16:33:17 Checking Daily data file for symbol YMZ14 for the date range from 2014-09-11 to 2014-10-28. | 2014-10-28 16:33:17 YMZ14/YM.20141200.CME_E [CV] Weekly #19 | Symbols used for continuous contract chart: | 2014-10-28 16:33:17 YMH12 | 2014-10-28 16:33:17 YMM12 | 2014-10-28 16:33:17 YMU12 | 2014-10-28 16:33:17 YMZ12 | 2014-10-28 16:33:17 YMH13 | 2014-10-28 16:33:17 YMM13 | 2014-10-28 16:33:17 YMU13 | 2014-10-28 16:33:17 YMZ13 | 2014-10-28 16:33:17 YMH14 | 2014-10-28 16:33:17 YMM14 | 2014-10-28 16:33:17 YMU14 | 2014-10-28 16:33:17 YMZ14 | 2014-10-28 16:33:17 YMZ14/YM.20141200.CME_E [CV] Weekly #19: Checking for volume based rollover dates. | 2014-10-28 16:33:17 YMZ14/YM.20141200.CME_E [CV] Weekly #19: Volume based rollover from YMH12 to YMM12 occurs at 2012-03-09 | 2014-10-28 16:33:17 YMZ14/YM.20141200.CME_E [CV] Weekly #19: Volume based rollover from YMM12 to YMU12 occurs at 2012-06-08 | 2014-10-28 16:33:17 YMZ14/YM.20141200.CME_E [CV] Weekly #19: Volume based rollover from YMU12 to YMZ12 occurs at 2012-09-14 | 2014-10-28 16:33:17 YMZ14/YM.20141200.CME_E [CV] Weekly #19: Volume based rollover from YMZ12 to YMH13 occurs at 2012-12-14 | 2014-10-28 16:33:17 YMZ14/YM.20141200.CME_E [CV] Weekly #19: Volume based rollover from YMH13 to YMM13 occurs at 2013-03-08 | 2014-10-28 16:33:17 YMZ14/YM.20141200.CME_E [CV] Weekly #19: Volume based rollover from YMM13 to YMU13 occurs at 2013-06-14 | 2014-10-28 16:33:17 YMZ14/YM.20141200.CME_E [CV] Weekly #19: Volume based rollover from YMU13 to YMZ13 occurs at 2013-09-13 | 2014-10-28 16:33:17 YMZ14/YM.20141200.CME_E [CV] Weekly #19: Volume based rollover from YMZ13 to YMH14 occurs at 2013-12-13 | 2014-10-28 16:33:17 YMZ14/YM.20141200.CME_E [CV] Weekly #19: Volume based rollover from YMH14 to YMM14 occurs at 2014-03-14 | 2014-10-28 16:33:17 YMZ14/YM.20141200.CME_E [CV] Weekly #19: Volume based rollover from YMM14 to YMU14 occurs at 2014-06-13 | 2014-10-28 16:33:17 YMZ14/YM.20141200.CME_E [CV] Weekly #19: Volume based rollover from YMU14 to YMZ14 occurs at 2014-09-12 | 2014-10-28 16:33:17 Date rule based rollover from ESH12 to next contract occurs at 2012-03-08. | 2014-10-28 16:33:17 Date rule based rollover from ESM12 to next contract occurs at 2012-06-07. | 2014-10-28 16:33:17 Date rule based rollover from ESU12 to next contract occurs at 2012-09-13. | 2014-10-28 16:33:17 Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13. | 2014-10-28 16:33:17 Date rule based rollover from ESH13 to next contract occurs at 2013-03-07. | 2014-10-28 16:33:17 Date rule based rollover from ESM13 to next contract occurs at 2013-06-13. | 2014-10-28 16:33:17 Date rule based rollover from ESU13 to next contract occurs at 2013-09-12. | 2014-10-28 16:33:17 Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12. | 2014-10-28 16:33:17 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2014-10-28 16:33:17 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2014-10-28 16:33:17 Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2014-10-28 16:33:17 Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2014-10-28 16:33:17 Checking Daily data file for symbol ESH12 for the date range from 2011-12-08 to 2012-03-08. | 2014-10-28 16:33:17 Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-07. | 2014-10-28 16:33:17 Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2014-10-28 16:33:17 Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2014-10-28 16:33:17 Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2014-10-28 16:33:17 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2014-10-28 16:33:17 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2014-10-28 16:33:17 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2014-10-28 16:33:17 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-10-28 16:33:17 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-10-28 16:33:17 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-10-28 16:33:17 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-10-28. | 2014-10-28 16:33:17 ESZ14/ES.20141200.CME_Eq [CV] Weekly #23 | Symbols used for continuous contract chart: | 2014-10-28 16:33:17 ESH12 | 2014-10-28 16:33:17 ESM12 | 2014-10-28 16:33:17 ESU12 | 2014-10-28 16:33:17 ESZ12 | 2014-10-28 16:33:17 ESH13 | 2014-10-28 16:33:17 ESM13 | 2014-10-28 16:33:17 ESU13 | 2014-10-28 16:33:17 ESZ13 | 2014-10-28 16:33:17 ESH14 | 2014-10-28 16:33:17 ESM14 | 2014-10-28 16:33:17 ESU14 | 2014-10-28 16:33:17 ESZ14 | 2014-10-28 16:33:17 ESZ14/ES.20141200.CME_Eq [CV] Weekly #23: Checking for volume based rollover dates. | 2014-10-28 16:33:17 ESZ14/ES.20141200.CME_Eq [CV] Weekly #23: Volume based rollover from ESH12 to ESM12 occurs at 2012-03-09 | 2014-10-28 16:33:17 ESZ14/ES.20141200.CME_Eq [CV] Weekly #23: Volume based rollover from ESM12 to ESU12 occurs at 2012-06-08 | 2014-10-28 16:33:17 ESZ14/ES.20141200.CME_Eq [CV] Weekly #23: Volume based rollover from ESU12 to ESZ12 occurs at 2012-09-14 | 2014-10-28 16:33:17 ESZ14/ES.20141200.CME_Eq [CV] Weekly #23: Volume based rollover from ESZ12 to ESH13 occurs at 2012-12-14 | 2014-10-28 16:33:17 ESZ14/ES.20141200.CME_Eq [CV] Weekly #23: Volume based rollover from ESH13 to ESM13 occurs at 2013-03-08 | 2014-10-28 16:33:17 ESZ14/ES.20141200.CME_Eq [CV] Weekly #23: Volume based rollover from ESM13 to ESU13 occurs at 2013-06-14 | 2014-10-28 16:33:17 ESZ14/ES.20141200.CME_Eq [CV] Weekly #23: Volume based rollover from ESU13 to ESZ13 occurs at 2013-09-13 | 2014-10-28 16:33:17 ESZ14/ES.20141200.CME_Eq [CV] Weekly #23: Volume based rollover from ESZ13 to ESH14 occurs at 2013-12-13 | 2014-10-28 16:33:17 ESZ14/ES.20141200.CME_Eq [CV] Weekly #23: Volume based rollover from ESH14 to ESM14 occurs at 2014-03-14 | 2014-10-28 16:33:17 ESZ14/ES.20141200.CME_Eq [CV] Weekly #23: Volume based rollover from ESM14 to ESU14 occurs at 2014-06-13 | 2014-10-28 16:33:17 ESZ14/ES.20141200.CME_Eq [CV] Weekly #23: Volume based rollover from ESU14 to ESZ14 occurs at 2014-09-12 | 2014-10-28 16:33:17 Date rule based rollover from RJH12 to next contract occurs at 2012-03-08. | 2014-10-28 16:33:17 Date rule based rollover from RJM12 to next contract occurs at 2012-06-07. | 2014-10-28 16:33:17 Date rule based rollover from RJU12 to next contract occurs at 2012-09-13. | 2014-10-28 16:33:17 Date rule based rollover from RJZ12 to next contract occurs at 2012-12-13. | 2014-10-28 16:33:17 Date rule based rollover from RJH13 to next contract occurs at 2013-03-07. | 2014-10-28 16:33:17 Date rule based rollover from RJM13 to next contract occurs at 2013-06-13. | 2014-10-28 16:33:17 Date rule based rollover from RJU13 to next contract occurs at 2013-09-12. | 2014-10-28 16:33:17 Date rule based rollover from RJZ13 to next contract occurs at 2013-12-12. | 2014-10-28 16:33:17 Date rule based rollover from RJH14 to next contract occurs at 2014-03-13. | 2014-10-28 16:33:17 Date rule based rollover from RJM14 to next contract occurs at 2014-06-12. | 2014-10-28 16:33:17 Date rule based rollover from RJU14 to next contract occurs at 2014-09-11. | 2014-10-28 16:33:17 Date rule based rollover from RJZ14 to next contract occurs at 2014-12-11. | 2014-10-28 16:33:17 Checking Daily data file for symbol RJH12 for the date range from 2011-12-08 to 2012-03-08. | 2014-10-28 16:33:17 Checking Daily data file for symbol RJM12 for the date range from 2012-03-08 to 2012-06-07. | 2014-10-28 16:33:17 Checking Daily data file for symbol RJU12 for the date range from 2012-06-07 to 2012-09-13. | 2014-10-28 16:33:17 Checking Daily data file for symbol RJZ12 for the date range from 2012-09-13 to 2012-12-13. | 2014-10-28 16:33:17 Checking Daily data file for symbol RJH13 for the date range from 2012-12-13 to 2013-03-07. | 2014-10-28 16:33:17 Checking Daily data file for symbol RJM13 for the date range from 2013-03-07 to 2013-06-13. | 2014-10-28 16:33:17 Checking Daily data file for symbol RJU13 for the date range from 2013-06-13 to 2013-09-12. | 2014-10-28 16:33:17 Checking Daily data file for symbol RJZ13 for the date range from 2013-09-12 to 2013-12-12. | 2014-10-28 16:33:17 Checking Daily data file for symbol RJH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-10-28 16:33:17 Checking Daily data file for symbol RJM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-10-28 16:33:17 Checking Daily data file for symbol RJU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-10-28 16:33:17 Checking Daily data file for symbol RJZ14 for the date range from 2014-09-11 to 2014-10-28. | 2014-10-28 16:33:17 RJZ14/TF.20141200.ICE_IN [CV] Weekly #24 | Symbols used for continuous contract chart: | 2014-10-28 16:33:17 RJH12 | 2014-10-28 16:33:17 RJM12 | 2014-10-28 16:33:17 RJU12 | 2014-10-28 16:33:17 RJZ12 | 2014-10-28 16:33:17 RJH13 | 2014-10-28 16:33:17 RJM13 | 2014-10-28 16:33:17 RJU13 | 2014-10-28 16:33:17 RJZ13 | 2014-10-28 16:33:17 RJH14 | 2014-10-28 16:33:17 RJM14 | 2014-10-28 16:33:17 RJU14 | 2014-10-28 16:33:17 RJZ14 | 2014-10-28 16:33:17 RJZ14/TF.20141200.ICE_IN [CV] Weekly #24: Checking for volume based rollover dates. | 2014-10-28 16:33:17 RJZ14/TF.20141200.ICE_IN [CV] Weekly #24: Volume based rollover from RJH12 to RJM12 occurs at 2012-03-09 | 2014-10-28 16:33:17 RJZ14/TF.20141200.ICE_IN [CV] Weekly #24: Volume based rollover from RJM12 to RJU12 occurs at 2012-06-08 | 2014-10-28 16:33:17 RJZ14/TF.20141200.ICE_IN [CV] Weekly #24: Volume based rollover from RJU12 to RJZ12 occurs at 2012-09-14 | 2014-10-28 16:33:17 RJZ14/TF.20141200.ICE_IN [CV] Weekly #24: Volume based rollover from RJZ12 to RJH13 occurs at 2012-12-14 | 2014-10-28 16:33:17 RJZ14/TF.20141200.ICE_IN [CV] Weekly #24: Volume based rollover from RJH13 to RJM13 occurs at 2013-03-08 | 2014-10-28 16:33:17 RJZ14/TF.20141200.ICE_IN [CV] Weekly #24: Volume based rollover from RJM13 to RJU13 occurs at 2013-06-14 | 2014-10-28 16:33:17 RJZ14/TF.20141200.ICE_IN [CV] Weekly #24: Volume based rollover from RJU13 to RJZ13 occurs at 2013-09-13 | 2014-10-28 16:33:17 RJZ14/TF.20141200.ICE_IN [CV] Weekly #24: Volume based rollover from RJZ13 to RJH14 occurs at 2013-12-13 | 2014-10-28 16:33:17 RJZ14/TF.20141200.ICE_IN [CV] Weekly #24: Volume based rollover from RJH14 to RJM14 occurs at 2014-03-14 | 2014-10-28 16:33:17 RJZ14/TF.20141200.ICE_IN [CV] Weekly #24: Volume based rollover from RJM14 to RJU14 occurs at 2014-06-13 | 2014-10-28 16:33:17 RJZ14/TF.20141200.ICE_IN [CV] Weekly #24: Volume based rollover from RJU14 to RJZ14 occurs at 2014-09-12 | 2014-10-28 16:33:17 Date rule based rollover from NQH12 to next contract occurs at 2012-03-08. | 2014-10-28 16:33:18 Date rule based rollover from NQM12 to next contract occurs at 2012-06-07. | 2014-10-28 16:33:18 Date rule based rollover from NQU12 to next contract occurs at 2012-09-13. | 2014-10-28 16:33:18 Date rule based rollover from NQZ12 to next contract occurs at 2012-12-13. | 2014-10-28 16:33:18 Date rule based rollover from NQH13 to next contract occurs at 2013-03-07. | 2014-10-28 16:33:18 Date rule based rollover from NQM13 to next contract occurs at 2013-06-13. | 2014-10-28 16:33:18 Date rule based rollover from NQU13 to next contract occurs at 2013-09-12. | 2014-10-28 16:33:18 Date rule based rollover from NQZ13 to next contract occurs at 2013-12-12. | 2014-10-28 16:33:18 Date rule based rollover from NQH14 to next contract occurs at 2014-03-13. | 2014-10-28 16:33:18 Date rule based rollover from NQM14 to next contract occurs at 2014-06-12. | 2014-10-28 16:33:18 Date rule based rollover from NQU14 to next contract occurs at 2014-09-11. | 2014-10-28 16:33:18 Date rule based rollover from NQZ14 to next contract occurs at 2014-12-11. | 2014-10-28 16:33:18 Checking Daily data file for symbol NQH12 for the date range from 2011-12-08 to 2012-03-08. | 2014-10-28 16:33:18 Checking Daily data file for symbol NQM12 for the date range from 2012-03-08 to 2012-06-07. | 2014-10-28 16:33:18 Checking Daily data file for symbol NQU12 for the date range from 2012-06-07 to 2012-09-13. | 2014-10-28 16:33:18 Checking Daily data file for symbol NQZ12 for the date range from 2012-09-13 to 2012-12-13. | 2014-10-28 16:33:18 Checking Daily data file for symbol NQH13 for the date range from 2012-12-13 to 2013-03-07. | 2014-10-28 16:33:18 Checking Daily data file for symbol NQM13 for the date range from 2013-03-07 to 2013-06-13. | 2014-10-28 16:33:18 Checking Daily data file for symbol NQU13 for the date range from 2013-06-13 to 2013-09-12. | 2014-10-28 16:33:18 Checking Daily data file for symbol NQZ13 for the date range from 2013-09-12 to 2013-12-12. | 2014-10-28 16:33:18 Checking Daily data file for symbol NQH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-10-28 16:33:18 Checking Daily data file for symbol NQM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-10-28 16:33:18 Checking Daily data file for symbol NQU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-10-28 16:33:18 Checking Daily data file for symbol NQZ14 for the date range from 2014-09-11 to 2014-10-28. | 2014-10-28 16:33:18 NQZ14/NQ.20141200.CME_Eq [CV] Weekly #25 | Symbols used for continuous contract chart: | 2014-10-28 16:33:18 NQH12 | 2014-10-28 16:33:18 NQM12 | 2014-10-28 16:33:18 NQU12 | 2014-10-28 16:33:18 NQZ12 | 2014-10-28 16:33:18 NQH13 | 2014-10-28 16:33:18 NQM13 | 2014-10-28 16:33:18 NQU13 | 2014-10-28 16:33:18 NQZ13 | 2014-10-28 16:33:18 NQH14 | 2014-10-28 16:33:18 NQM14 | 2014-10-28 16:33:18 NQU14 | 2014-10-28 16:33:18 NQZ14 | 2014-10-28 16:33:18 NQZ14/NQ.20141200.CME_Eq [CV] Weekly #25: Checking for volume based rollover dates. | 2014-10-28 16:33:18 NQZ14/NQ.20141200.CME_Eq [CV] Weekly #25: Volume based rollover from NQH12 to NQM12 occurs at 2012-03-09 | 2014-10-28 16:33:18 NQZ14/NQ.20141200.CME_Eq [CV] Weekly #25: Volume based rollover from NQM12 to NQU12 occurs at 2012-06-08 | 2014-10-28 16:33:18 NQZ14/NQ.20141200.CME_Eq [CV] Weekly #25: Volume based rollover from NQU12 to NQZ12 occurs at 2012-09-14 | 2014-10-28 16:33:18 NQZ14/NQ.20141200.CME_Eq [CV] Weekly #25: Volume based rollover from NQZ12 to NQH13 occurs at 2012-12-14 | 2014-10-28 16:33:18 NQZ14/NQ.20141200.CME_Eq [CV] Weekly #25: Volume based rollover from NQH13 to NQM13 occurs at 2013-03-08 | 2014-10-28 16:33:18 NQZ14/NQ.20141200.CME_Eq [CV] Weekly #25: Volume based rollover from NQM13 to NQU13 occurs at 2013-06-14 | 2014-10-28 16:33:18 NQZ14/NQ.20141200.CME_Eq [CV] Weekly #25: Volume based rollover from NQU13 to NQZ13 occurs at 2013-09-13 | 2014-10-28 16:33:18 NQZ14/NQ.20141200.CME_Eq [CV] Weekly #25: Volume based rollover from NQZ13 to NQH14 occurs at 2013-12-13 | 2014-10-28 16:33:18 NQZ14/NQ.20141200.CME_Eq [CV] Weekly #25: Volume based rollover from NQH14 to NQM14 occurs at 2014-03-14 | 2014-10-28 16:33:18 NQZ14/NQ.20141200.CME_Eq [CV] Weekly #25: Volume based rollover from NQM14 to NQU14 occurs at 2014-06-13 | 2014-10-28 16:33:18 NQZ14/NQ.20141200.CME_Eq [CV] Weekly #25: Volume based rollover from NQU14 to NQZ14 occurs at 2014-09-12 | 2014-10-28 16:33:18 HTTP connection to www.sierrachart.com:80 (1436) | Closed. No error. | 2014-10-28 16:33:19 HTTP connection to www.sierrachart.com:80 (1436) | Shutdown and closed. | 2014-10-28 16:33:19 HD Request # 2 | Downloading Historical Daily chart data for YMZ14. Starting date: 2014-10-27. Service: cts | 2014-10-28 16:33:19 HD Request # 2 | Requesting historical Daily data for YMZ14 starting at 2014-10-26 | 2014-10-28 16:33:19 HD Request # 2 | Receiving historical Daily data for YMZ14 starting at 2014-10-27 | 2014-10-28 16:33:19 Writing historical Daily data for YMZ14 to the file YMZ14.dly | 2014-10-28 16:33:19 HD Request # 2 | Received 2 records from 2014-10-27 00:00:00 to 2014-10-28 00:00:00 (2.0 days) and wrote 2 records for YMZ14 | 2014-10-28 16:33:19 HD Request # 2 | Daily download COMPLETE for YMZ14. Completion time: 0s. Unique request ID: 1 | 2014-10-28 16:33:19 Date rule based rollover from YMH12 to next contract occurs at 2012-03-08. | 2014-10-28 16:33:19 Date rule based rollover from YMM12 to next contract occurs at 2012-06-07. | 2014-10-28 16:33:19 Date rule based rollover from YMU12 to next contract occurs at 2012-09-13. | 2014-10-28 16:33:19 Date rule based rollover from YMZ12 to next contract occurs at 2012-12-13. | 2014-10-28 16:33:19 Date rule based rollover from YMH13 to next contract occurs at 2013-03-07. | 2014-10-28 16:33:19 Date rule based rollover from YMM13 to next contract occurs at 2013-06-13. | 2014-10-28 16:33:19 Date rule based rollover from YMU13 to next contract occurs at 2013-09-12. | 2014-10-28 16:33:19 Date rule based rollover from YMZ13 to next contract occurs at 2013-12-12. | 2014-10-28 16:33:19 Date rule based rollover from YMH14 to next contract occurs at 2014-03-13. | 2014-10-28 16:33:19 Date rule based rollover from YMM14 to next contract occurs at 2014-06-12. | 2014-10-28 16:33:19 Date rule based rollover from YMU14 to next contract occurs at 2014-09-11. | 2014-10-28 16:33:19 Date rule based rollover from YMZ14 to next contract occurs at 2014-12-11. | 2014-10-28 16:33:19 Checking Daily data file for symbol YMH12 for the date range from 2011-12-08 to 2012-03-08. | 2014-10-28 16:33:19 Checking Daily data file for symbol YMM12 for the date range from 2012-03-08 to 2012-06-07. | 2014-10-28 16:33:19 Checking Daily data file for symbol YMU12 for the date range from 2012-06-07 to 2012-09-13. | 2014-10-28 16:33:19 Checking Daily data file for symbol YMZ12 for the date range from 2012-09-13 to 2012-12-13. | 2014-10-28 16:33:19 Checking Daily data file for symbol YMH13 for the date range from 2012-12-13 to 2013-03-07. | 2014-10-28 16:33:20 Checking Daily data file for symbol YMM13 for the date range from 2013-03-07 to 2013-06-13. | 2014-10-28 16:33:20 Checking Daily data file for symbol YMU13 for the date range from 2013-06-13 to 2013-09-12. | 2014-10-28 16:33:20 Checking Daily data file for symbol YMZ13 for the date range from 2013-09-12 to 2013-12-12. | 2014-10-28 16:33:20 Checking Daily data file for symbol YMH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-10-28 16:33:20 Checking Daily data file for symbol YMM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-10-28 16:33:20 Checking Daily data file for symbol YMU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-10-28 16:33:20 Checking Daily data file for symbol YMZ14 for the date range from 2014-09-11 to 2014-10-28. | 2014-10-28 16:33:20 YMZ14/YM.20141200.CME_E [CV] Weekly #19 | Symbols used for continuous contract chart: | 2014-10-28 16:33:20 YMH12 | 2014-10-28 16:33:20 YMM12 | 2014-10-28 16:33:20 YMU12 | 2014-10-28 16:33:20 YMZ12 | 2014-10-28 16:33:20 YMH13 | 2014-10-28 16:33:20 YMM13 | 2014-10-28 16:33:20 YMU13 | 2014-10-28 16:33:20 YMZ13 | 2014-10-28 16:33:20 YMH14 | 2014-10-28 16:33:20 YMM14 | 2014-10-28 16:33:20 YMU14 | 2014-10-28 16:33:20 YMZ14 | 2014-10-28 16:33:20 YMZ14/YM.20141200.CME_E [CV] Weekly #19 | Waiting for historical downloads to complete with the IDs: 1, | 2014-10-28 16:33:20 HD Request # 3 | Downloading Historical Daily chart data for ESZ14. Starting date: 2014-10-27. Service: cts | 2014-10-28 16:33:20 HD Request # 3 | Requesting historical Daily data for ESZ14 starting at 2014-10-26 | 2014-10-28 16:33:20 HD Request # 3 | Receiving historical Daily data for ESZ14 starting at 2014-10-27 | 2014-10-28 16:33:20 Writing historical Daily data for ESZ14 to the file ESZ14.dly | 2014-10-28 16:33:20 HD Request # 3 | Received 2 records from 2014-10-27 00:00:00 to 2014-10-28 00:00:00 (2.0 days) and wrote 2 records for ESZ14 | 2014-10-28 16:33:20 HD Request # 3 | Daily download COMPLETE for ESZ14. Completion time: 0s. Unique request ID: 2 | 2014-10-28 16:33:20 Date rule based rollover from ESH12 to next contract occurs at 2012-03-08. | 2014-10-28 16:33:20 Date rule based rollover from ESM12 to next contract occurs at 2012-06-07. | 2014-10-28 16:33:20 Date rule based rollover from ESU12 to next contract occurs at 2012-09-13. | 2014-10-28 16:33:20 Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13. | 2014-10-28 16:33:20 Date rule based rollover from ESH13 to next contract occurs at 2013-03-07. | 2014-10-28 16:33:20 Date rule based rollover from ESM13 to next contract occurs at 2013-06-13. | 2014-10-28 16:33:20 Date rule based rollover from ESU13 to next contract occurs at 2013-09-12. | 2014-10-28 16:33:20 Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12. | 2014-10-28 16:33:20 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2014-10-28 16:33:20 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2014-10-28 16:33:20 Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2014-10-28 16:33:20 Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2014-10-28 16:33:20 Checking Daily data file for symbol ESH12 for the date range from 2011-12-08 to 2012-03-08. | 2014-10-28 16:33:20 Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-07. | 2014-10-28 16:33:20 Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2014-10-28 16:33:20 Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2014-10-28 16:33:20 Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2014-10-28 16:33:20 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2014-10-28 16:33:20 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2014-10-28 16:33:20 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2014-10-28 16:33:20 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-10-28 16:33:20 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-10-28 16:33:20 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-10-28 16:33:20 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-10-28. | 2014-10-28 16:33:20 ESZ14/ES.20141200.CME_Eq [CV] Weekly #23 | Symbols used for continuous contract chart: | 2014-10-28 16:33:20 ESH12 | 2014-10-28 16:33:20 ESM12 | 2014-10-28 16:33:20 ESU12 | 2014-10-28 16:33:20 ESZ12 | 2014-10-28 16:33:20 ESH13 | 2014-10-28 16:33:20 ESM13 | 2014-10-28 16:33:20 ESU13 | 2014-10-28 16:33:20 ESZ13 | 2014-10-28 16:33:20 ESH14 | 2014-10-28 16:33:20 ESM14 | 2014-10-28 16:33:20 ESU14 | 2014-10-28 16:33:20 ESZ14 | 2014-10-28 16:33:20 ESZ14/ES.20141200.CME_Eq [CV] Weekly #23 | Waiting for historical downloads to complete with the IDs: 2, | 2014-10-28 16:33:20 HD Request # 4 | Downloading Historical Daily chart data for NQZ14. Starting date: 2014-10-27. Service: cts | 2014-10-28 16:33:20 HD Request # 4 | Requesting historical Daily data for NQZ14 starting at 2014-10-26 | 2014-10-28 16:33:20 HD Request # 4 | Receiving historical Daily data for NQZ14 starting at 2014-10-27 | 2014-10-28 16:33:20 Writing historical Daily data for NQZ14 to the file NQZ14.dly | 2014-10-28 16:33:20 HD Request # 4 | Received 2 records from 2014-10-27 00:00:00 to 2014-10-28 00:00:00 (2.0 days) and wrote 2 records for NQZ14 | 2014-10-28 16:33:20 HD Request # 4 | Daily download COMPLETE for NQZ14. Completion time: 0s. Unique request ID: 3 | 2014-10-28 16:33:20 Date rule based rollover from NQH12 to next contract occurs at 2012-03-08. | 2014-10-28 16:33:20 Date rule based rollover from NQM12 to next contract occurs at 2012-06-07. | 2014-10-28 16:33:20 Date rule based rollover from NQU12 to next contract occurs at 2012-09-13. | 2014-10-28 16:33:20 Date rule based rollover from NQZ12 to next contract occurs at 2012-12-13. | 2014-10-28 16:33:20 Date rule based rollover from NQH13 to next contract occurs at 2013-03-07. | 2014-10-28 16:33:20 Date rule based rollover from NQM13 to next contract occurs at 2013-06-13. | 2014-10-28 16:33:20 Date rule based rollover from NQU13 to next contract occurs at 2013-09-12. | 2014-10-28 16:33:20 Date rule based rollover from NQZ13 to next contract occurs at 2013-12-12. | 2014-10-28 16:33:20 Date rule based rollover from NQH14 to next contract occurs at 2014-03-13. | 2014-10-28 16:33:20 Date rule based rollover from NQM14 to next contract occurs at 2014-06-12. | 2014-10-28 16:33:20 Date rule based rollover from NQU14 to next contract occurs at 2014-09-11. | 2014-10-28 16:33:20 Date rule based rollover from NQZ14 to next contract occurs at 2014-12-11. | 2014-10-28 16:33:20 Checking Daily data file for symbol NQH12 for the date range from 2011-12-08 to 2012-03-08. | 2014-10-28 16:33:20 Checking Daily data file for symbol NQM12 for the date range from 2012-03-08 to 2012-06-07. | 2014-10-28 16:33:20 Checking Daily data file for symbol NQU12 for the date range from 2012-06-07 to 2012-09-13. | 2014-10-28 16:33:20 Checking Daily data file for symbol NQZ12 for the date range from 2012-09-13 to 2012-12-13. | 2014-10-28 16:33:20 Checking Daily data file for symbol NQH13 for the date range from 2012-12-13 to 2013-03-07. | 2014-10-28 16:33:20 Checking Daily data file for symbol NQM13 for the date range from 2013-03-07 to 2013-06-13. | 2014-10-28 16:33:20 Checking Daily data file for symbol NQU13 for the date range from 2013-06-13 to 2013-09-12. | 2014-10-28 16:33:20 Checking Daily data file for symbol NQZ13 for the date range from 2013-09-12 to 2013-12-12. | 2014-10-28 16:33:20 Checking Daily data file for symbol NQH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-10-28 16:33:20 Checking Daily data file for symbol NQM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-10-28 16:33:20 Checking Daily data file for symbol NQU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-10-28 16:33:20 Checking Daily data file for symbol NQZ14 for the date range from 2014-09-11 to 2014-10-28. | 2014-10-28 16:33:20 NQZ14/NQ.20141200.CME_Eq [CV] Weekly #25 | Symbols used for continuous contract chart: | 2014-10-28 16:33:20 NQH12 | 2014-10-28 16:33:20 NQM12 | 2014-10-28 16:33:20 NQU12 | 2014-10-28 16:33:20 NQZ12 | 2014-10-28 16:33:20 NQH13 | 2014-10-28 16:33:20 NQM13 | 2014-10-28 16:33:20 NQU13 | 2014-10-28 16:33:20 NQZ13 | 2014-10-28 16:33:20 NQH14 | 2014-10-28 16:33:20 NQM14 | 2014-10-28 16:33:20 NQU14 | 2014-10-28 16:33:20 NQZ14 | 2014-10-28 16:33:20 NQZ14/NQ.20141200.CME_Eq [CV] Weekly #25 | Waiting for historical downloads to complete with the IDs: 3, | 2014-10-28 16:33:20 HD Request # 5 | Downloading Historical Daily chart data for RJZ14. Starting date: 2014-10-27. Service: cts | 2014-10-28 16:33:20 HD Request # 5 | Requesting historical Daily data for RJZ14 starting at 2014-10-26 | 2014-10-28 16:33:20 HD Request # 5 | Receiving historical Daily data for RJZ14 starting at 2014-10-27 | 2014-10-28 16:33:20 Writing historical Daily data for RJZ14 to the file RJZ14.dly | 2014-10-28 16:33:20 HD Request # 5 | Received 2 records from 2014-10-27 00:00:00 to 2014-10-28 00:00:00 (2.0 days) and wrote 2 records for RJZ14 | 2014-10-28 16:33:20 HD Request # 5 | Daily download COMPLETE for RJZ14. Completion time: 0s. Unique request ID: 4 | 2014-10-28 16:33:20 Date rule based rollover from RJH12 to next contract occurs at 2012-03-08. | 2014-10-28 16:33:20 Date rule based rollover from RJM12 to next contract occurs at 2012-06-07. | 2014-10-28 16:33:20 Date rule based rollover from RJU12 to next contract occurs at 2012-09-13. | 2014-10-28 16:33:20 Date rule based rollover from RJZ12 to next contract occurs at 2012-12-13. | 2014-10-28 16:33:20 Date rule based rollover from RJH13 to next contract occurs at 2013-03-07. | 2014-10-28 16:33:20 Date rule based rollover from RJM13 to next contract occurs at 2013-06-13. | 2014-10-28 16:33:20 Date rule based rollover from RJU13 to next contract occurs at 2013-09-12. | 2014-10-28 16:33:20 Date rule based rollover from RJZ13 to next contract occurs at 2013-12-12. | 2014-10-28 16:33:20 Date rule based rollover from RJH14 to next contract occurs at 2014-03-13. | 2014-10-28 16:33:20 Date rule based rollover from RJM14 to next contract occurs at 2014-06-12. | 2014-10-28 16:33:20 Date rule based rollover from RJU14 to next contract occurs at 2014-09-11. | 2014-10-28 16:33:20 Date rule based rollover from RJZ14 to next contract occurs at 2014-12-11. | 2014-10-28 16:33:20 Checking Daily data file for symbol RJH12 for the date range from 2011-12-08 to 2012-03-08. | 2014-10-28 16:33:20 Checking Daily data file for symbol RJM12 for the date range from 2012-03-08 to 2012-06-07. | 2014-10-28 16:33:20 Checking Daily data file for symbol RJU12 for the date range from 2012-06-07 to 2012-09-13. | 2014-10-28 16:33:20 Checking Daily data file for symbol RJZ12 for the date range from 2012-09-13 to 2012-12-13. | 2014-10-28 16:33:20 Checking Daily data file for symbol RJH13 for the date range from 2012-12-13 to 2013-03-07. | 2014-10-28 16:33:20 Checking Daily data file for symbol RJM13 for the date range from 2013-03-07 to 2013-06-13. | 2014-10-28 16:33:20 Checking Daily data file for symbol RJU13 for the date range from 2013-06-13 to 2013-09-12. | 2014-10-28 16:33:20 Checking Daily data file for symbol RJZ13 for the date range from 2013-09-12 to 2013-12-12. | 2014-10-28 16:33:20 Checking Daily data file for symbol RJH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-10-28 16:33:20 Checking Daily data file for symbol RJM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-10-28 16:33:20 Checking Daily data file for symbol RJU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-10-28 16:33:20 Checking Daily data file for symbol RJZ14 for the date range from 2014-09-11 to 2014-10-28. | 2014-10-28 16:33:20 RJZ14/TF.20141200.ICE_IN [CV] Weekly #24 | Symbols used for continuous contract chart: | 2014-10-28 16:33:20 RJH12 | 2014-10-28 16:33:20 RJM12 | 2014-10-28 16:33:20 RJU12 | 2014-10-28 16:33:20 RJZ12 | 2014-10-28 16:33:20 RJH13 | 2014-10-28 16:33:20 RJM13 | 2014-10-28 16:33:20 RJU13 | 2014-10-28 16:33:20 RJZ13 | 2014-10-28 16:33:20 RJH14 | 2014-10-28 16:33:20 RJM14 | 2014-10-28 16:33:20 RJU14 | 2014-10-28 16:33:20 RJZ14 | 2014-10-28 16:33:20 RJZ14/TF.20141200.ICE_IN [CV] Weekly #24 | Waiting for historical downloads to complete with the IDs: 4, | 2014-10-28 16:33:20 YMZ14/YM.20141200.CME_E [CV] Weekly #19: Download is complete for all contract months in chart. Proceeding with data load. | 2014-10-28 16:33:20 YMZ14/YM.20141200.CME_E [CV] Weekly #19: Checking for volume based rollover dates. | 2014-10-28 16:33:20 YMZ14/YM.20141200.CME_E [CV] Weekly #19: Volume based rollover from YMH12 to YMM12 occurs at 2012-03-09 | 2014-10-28 16:33:20 YMZ14/YM.20141200.CME_E [CV] Weekly #19: Volume based rollover from YMM12 to YMU12 occurs at 2012-06-08 | 2014-10-28 16:33:20 YMZ14/YM.20141200.CME_E [CV] Weekly #19: Volume based rollover from YMU12 to YMZ12 occurs at 2012-09-14 | 2014-10-28 16:33:20 YMZ14/YM.20141200.CME_E [CV] Weekly #19: Volume based rollover from YMZ12 to YMH13 occurs at 2012-12-14 | 2014-10-28 16:33:20 YMZ14/YM.20141200.CME_E [CV] Weekly #19: Volume based rollover from YMH13 to YMM13 occurs at 2013-03-08 | 2014-10-28 16:33:20 YMZ14/YM.20141200.CME_E [CV] Weekly #19: Volume based rollover from YMM13 to YMU13 occurs at 2013-06-14 | 2014-10-28 16:33:20 YMZ14/YM.20141200.CME_E [CV] Weekly #19: Volume based rollover from YMU13 to YMZ13 occurs at 2013-09-13 | 2014-10-28 16:33:20 YMZ14/YM.20141200.CME_E [CV] Weekly #19: Volume based rollover from YMZ13 to YMH14 occurs at 2013-12-13 | 2014-10-28 16:33:20 YMZ14/YM.20141200.CME_E [CV] Weekly #19: Volume based rollover from YMH14 to YMM14 occurs at 2014-03-14 | 2014-10-28 16:33:20 YMZ14/YM.20141200.CME_E [CV] Weekly #19: Volume based rollover from YMM14 to YMU14 occurs at 2014-06-13 | 2014-10-28 16:33:20 YMZ14/YM.20141200.CME_E [CV] Weekly #19: Volume based rollover from YMU14 to YMZ14 occurs at 2014-09-12 | 2014-10-28 16:33:20 ESZ14/ES.20141200.CME_Eq [CV] Weekly #23: Download is complete for all contract months in chart. Proceeding with data load. | 2014-10-28 16:33:21 ESZ14/ES.20141200.CME_Eq [CV] Weekly #23: Checking for volume based rollover dates. | 2014-10-28 16:33:21 ESZ14/ES.20141200.CME_Eq [CV] Weekly #23: Volume based rollover from ESH12 to ESM12 occurs at 2012-03-09 | 2014-10-28 16:33:21 ESZ14/ES.20141200.CME_Eq [CV] Weekly #23: Volume based rollover from ESM12 to ESU12 occurs at 2012-06-08 | 2014-10-28 16:33:21 ESZ14/ES.20141200.CME_Eq [CV] Weekly #23: Volume based rollover from ESU12 to ESZ12 occurs at 2012-09-14 | 2014-10-28 16:33:21 ESZ14/ES.20141200.CME_Eq [CV] Weekly #23: Volume based rollover from ESZ12 to ESH13 occurs at 2012-12-14 | 2014-10-28 16:33:21 ESZ14/ES.20141200.CME_Eq [CV] Weekly #23: Volume based rollover from ESH13 to ESM13 occurs at 2013-03-08 | 2014-10-28 16:33:21 ESZ14/ES.20141200.CME_Eq [CV] Weekly #23: Volume based rollover from ESM13 to ESU13 occurs at 2013-06-14 | 2014-10-28 16:33:21 ESZ14/ES.20141200.CME_Eq [CV] Weekly #23: Volume based rollover from ESU13 to ESZ13 occurs at 2013-09-13 | 2014-10-28 16:33:21 ESZ14/ES.20141200.CME_Eq [CV] Weekly #23: Volume based rollover from ESZ13 to ESH14 occurs at 2013-12-13 | 2014-10-28 16:33:21 ESZ14/ES.20141200.CME_Eq [CV] Weekly #23: Volume based rollover from ESH14 to ESM14 occurs at 2014-03-14 | 2014-10-28 16:33:21 ESZ14/ES.20141200.CME_Eq [CV] Weekly #23: Volume based rollover from ESM14 to ESU14 occurs at 2014-06-13 | 2014-10-28 16:33:21 ESZ14/ES.20141200.CME_Eq [CV] Weekly #23: Volume based rollover from ESU14 to ESZ14 occurs at 2014-09-12 | 2014-10-28 16:33:21 NQZ14/NQ.20141200.CME_Eq [CV] Weekly #25: Download is complete for all contract months in chart. Proceeding with data load. | 2014-10-28 16:33:21 NQZ14/NQ.20141200.CME_Eq [CV] Weekly #25: Checking for volume based rollover dates. | 2014-10-28 16:33:21 NQZ14/NQ.20141200.CME_Eq [CV] Weekly #25: Volume based rollover from NQH12 to NQM12 occurs at 2012-03-09 | 2014-10-28 16:33:21 NQZ14/NQ.20141200.CME_Eq [CV] Weekly #25: Volume based rollover from NQM12 to NQU12 occurs at 2012-06-08 | 2014-10-28 16:33:21 NQZ14/NQ.20141200.CME_Eq [CV] Weekly #25: Volume based rollover from NQU12 to NQZ12 occurs at 2012-09-14 | 2014-10-28 16:33:21 NQZ14/NQ.20141200.CME_Eq [CV] Weekly #25: Volume based rollover from NQZ12 to NQH13 occurs at 2012-12-14 | 2014-10-28 16:33:21 NQZ14/NQ.20141200.CME_Eq [CV] Weekly #25: Volume based rollover from NQH13 to NQM13 occurs at 2013-03-08 | 2014-10-28 16:33:21 NQZ14/NQ.20141200.CME_Eq [CV] Weekly #25: Volume based rollover from NQM13 to NQU13 occurs at 2013-06-14 | 2014-10-28 16:33:21 NQZ14/NQ.20141200.CME_Eq [CV] Weekly #25: Volume based rollover from NQU13 to NQZ13 occurs at 2013-09-13 | 2014-10-28 16:33:21 NQZ14/NQ.20141200.CME_Eq [CV] Weekly #25: Volume based rollover from NQZ13 to NQH14 occurs at 2013-12-13 | 2014-10-28 16:33:21 NQZ14/NQ.20141200.CME_Eq [CV] Weekly #25: Volume based rollover from NQH14 to NQM14 occurs at 2014-03-14 | 2014-10-28 16:33:21 NQZ14/NQ.20141200.CME_Eq [CV] Weekly #25: Volume based rollover from NQM14 to NQU14 occurs at 2014-06-13 | 2014-10-28 16:33:21 NQZ14/NQ.20141200.CME_Eq [CV] Weekly #25: Volume based rollover from NQU14 to NQZ14 occurs at 2014-09-12 | 2014-10-28 16:33:21 RJZ14/TF.20141200.ICE_IN [CV] Weekly #24: Download is complete for all contract months in chart. Proceeding with data load. | 2014-10-28 16:33:21 RJZ14/TF.20141200.ICE_IN [CV] Weekly #24: Checking for volume based rollover dates. | 2014-10-28 16:33:21 RJZ14/TF.20141200.ICE_IN [CV] Weekly #24: Volume based rollover from RJH12 to RJM12 occurs at 2012-03-09 | 2014-10-28 16:33:21 RJZ14/TF.20141200.ICE_IN [CV] Weekly #24: Volume based rollover from RJM12 to RJU12 occurs at 2012-06-08 | 2014-10-28 16:33:21 RJZ14/TF.20141200.ICE_IN [CV] Weekly #24: Volume based rollover from RJU12 to RJZ12 occurs at 2012-09-14 | 2014-10-28 16:33:21 RJZ14/TF.20141200.ICE_IN [CV] Weekly #24: Volume based rollover from RJZ12 to RJH13 occurs at 2012-12-14 | 2014-10-28 16:33:21 RJZ14/TF.20141200.ICE_IN [CV] Weekly #24: Volume based rollover from RJH13 to RJM13 occurs at 2013-03-08 | 2014-10-28 16:33:21 RJZ14/TF.20141200.ICE_IN [CV] Weekly #24: Volume based rollover from RJM13 to RJU13 occurs at 2013-06-14 | 2014-10-28 16:33:21 RJZ14/TF.20141200.ICE_IN [CV] Weekly #24: Volume based rollover from RJU13 to RJZ13 occurs at 2013-09-13 | 2014-10-28 16:33:21 RJZ14/TF.20141200.ICE_IN [CV] Weekly #24: Volume based rollover from RJZ13 to RJH14 occurs at 2013-12-13 | 2014-10-28 16:33:21 RJZ14/TF.20141200.ICE_IN [CV] Weekly #24: Volume based rollover from RJH14 to RJM14 occurs at 2014-03-14 | 2014-10-28 16:33:21 RJZ14/TF.20141200.ICE_IN [CV] Weekly #24: Volume based rollover from RJM14 to RJU14 occurs at 2014-06-13 | 2014-10-28 16:33:21 RJZ14/TF.20141200.ICE_IN [CV] Weekly #24: Volume based rollover from RJU14 to RJZ14 occurs at 2014-09-12 | 2014-10-28 16:33:21 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:33:21 CTS FIX - Firm: Phillip | 2014-10-28 16:33:21 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 208.116.215.102 | 2014-10-28 16:33:21 CTS FIX socket (1984) | Connected. | 2014-10-28 16:33:21 CTS FIX socket (1984) | Starting SSL connection. | 2014-10-28 16:33:21 CTS FIX socket (1984) | SSL connection established. | 2014-10-28 16:33:23 CTS FIX: Sending the Logon message. | 2014-10-28 16:33:25 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:33:25 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:33:25 CTS FIX socket (1984) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:33:25 CTS FIX socket (1984) | SSL has been shut down. | 2014-10-28 16:33:25 CTS FIX socket (1984) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:33:25 CTS FIX socket (1984) | Shutdown and closed. | 2014-10-28 16:33:25 CTS FIX: Logged out and disconnected. | 2014-10-28 16:33:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:33:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:33:25 CTS FIX: Disconnected. | 2014-10-28 16:33:26 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:33:26 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:33:29 CTS FIX - Firm: Phillip | 2014-10-28 16:33:29 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 208.116.215.102 | 2014-10-28 16:33:29 CTS FIX socket (2496) | Connected. | 2014-10-28 16:33:29 CTS FIX socket (2496) | Starting SSL connection. | 2014-10-28 16:33:29 CTS FIX socket (2496) | SSL connection established. | 2014-10-28 16:33:29 CTS FIX: Sending the Logon message. | 2014-10-28 16:33:29 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:33:29 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:33:29 CTS FIX socket (2496) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:33:29 CTS FIX socket (2496) | SSL has been shut down. | 2014-10-28 16:33:29 CTS FIX socket (2496) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:33:29 CTS FIX socket (2496) | Shutdown and closed. | 2014-10-28 16:33:29 CTS FIX: Logged out and disconnected. | 2014-10-28 16:33:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:33:29 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:33:29 CTS FIX: Disconnected. | 2014-10-28 16:33:29 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:33:29 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:33:32 CTS FIX - Firm: Phillip | 2014-10-28 16:33:32 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 74.201.6.106 | 2014-10-28 16:33:32 CTS FIX socket (2632) | Connected. | 2014-10-28 16:33:32 CTS FIX socket (2632) | Starting SSL connection. | 2014-10-28 16:33:32 CTS FIX socket (2632) | SSL connection established. | 2014-10-28 16:33:32 CTS FIX: Sending the Logon message. | 2014-10-28 16:33:33 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:33:33 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:33:33 CTS FIX socket (2632) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:33:33 CTS FIX socket (2632) | SSL has been shut down. | 2014-10-28 16:33:33 CTS FIX socket (2632) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:33:33 CTS FIX socket (2632) | Shutdown and closed. | 2014-10-28 16:33:33 CTS FIX: Logged out and disconnected. | 2014-10-28 16:33:33 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:33:33 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:33:33 CTS FIX: Disconnected. | 2014-10-28 16:33:33 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:33:33 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:33:36 CTS FIX - Firm: Phillip | 2014-10-28 16:33:36 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 74.201.6.106 | 2014-10-28 16:33:36 CTS FIX socket (2628) | Connected. | 2014-10-28 16:33:36 CTS FIX socket (2628) | Starting SSL connection. | 2014-10-28 16:33:36 CTS FIX socket (2628) | SSL connection established. | 2014-10-28 16:33:36 CTS FIX: Sending the Logon message. | 2014-10-28 16:33:36 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:33:36 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:33:36 CTS FIX socket (2628) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:33:36 CTS FIX socket (2628) | SSL has been shut down. | 2014-10-28 16:33:36 CTS FIX socket (2628) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:33:36 CTS FIX socket (2628) | Shutdown and closed. | 2014-10-28 16:33:36 CTS FIX: Logged out and disconnected. | 2014-10-28 16:33:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:33:36 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:33:36 CTS FIX: Disconnected. | 2014-10-28 16:33:36 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:33:36 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:33:39 CTS FIX - Firm: Phillip | 2014-10-28 16:33:39 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 74.201.6.106 | 2014-10-28 16:33:39 CTS FIX socket (2632) | Connected. | 2014-10-28 16:33:39 CTS FIX socket (2632) | Starting SSL connection. | 2014-10-28 16:33:39 CTS FIX socket (2632) | SSL connection established. | 2014-10-28 16:33:39 CTS FIX: Sending the Logon message. | 2014-10-28 16:33:40 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:33:40 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:33:40 CTS FIX socket (2632) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:33:40 CTS FIX socket (2632) | SSL has been shut down. | 2014-10-28 16:33:40 CTS FIX socket (2632) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:33:40 CTS FIX socket (2632) | Shutdown and closed. | 2014-10-28 16:33:40 CTS FIX: Logged out and disconnected. | 2014-10-28 16:33:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:33:40 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:33:40 CTS FIX: Disconnected. | 2014-10-28 16:33:40 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:33:40 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:33:43 CTS FIX - Firm: Phillip | 2014-10-28 16:33:43 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 69.44.110.106 | 2014-10-28 16:33:43 CTS FIX socket (2628) | Connected. | 2014-10-28 16:33:43 CTS FIX socket (2628) | Starting SSL connection. | 2014-10-28 16:33:43 CTS FIX socket (2628) | SSL connection established. | 2014-10-28 16:33:43 CTS FIX: Sending the Logon message. | 2014-10-28 16:33:43 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:33:43 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:33:43 CTS FIX socket (2628) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:33:43 CTS FIX socket (2628) | SSL has been shut down. | 2014-10-28 16:33:43 CTS FIX socket (2628) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:33:43 CTS FIX socket (2628) | Shutdown and closed. | 2014-10-28 16:33:43 CTS FIX: Logged out and disconnected. | 2014-10-28 16:33:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:33:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:33:43 CTS FIX: Disconnected. | 2014-10-28 16:33:43 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:33:43 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:33:46 CTS FIX - Firm: Phillip | 2014-10-28 16:33:46 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 69.44.110.106 | 2014-10-28 16:33:46 CTS FIX socket (2632) | Connected. | 2014-10-28 16:33:46 CTS FIX socket (2632) | Starting SSL connection. | 2014-10-28 16:33:46 CTS FIX socket (2632) | SSL connection established. | 2014-10-28 16:33:46 CTS FIX: Sending the Logon message. | 2014-10-28 16:33:47 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:33:47 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:33:47 CTS FIX socket (2632) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:33:47 CTS FIX socket (2632) | SSL has been shut down. | 2014-10-28 16:33:47 CTS FIX socket (2632) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:33:47 CTS FIX socket (2632) | Shutdown and closed. | 2014-10-28 16:33:47 CTS FIX: Logged out and disconnected. | 2014-10-28 16:33:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:33:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:33:47 CTS FIX: Disconnected. | 2014-10-28 16:33:47 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:33:47 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:33:50 CTS FIX - Firm: Phillip | 2014-10-28 16:33:50 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 69.44.110.106 | 2014-10-28 16:33:50 CTS FIX socket (2628) | Connected. | 2014-10-28 16:33:50 CTS FIX socket (2628) | Starting SSL connection. | 2014-10-28 16:33:50 CTS FIX socket (2628) | SSL connection established. | 2014-10-28 16:33:50 CTS FIX: Sending the Logon message. | 2014-10-28 16:33:50 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:33:50 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:33:50 CTS FIX socket (2628) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:33:50 CTS FIX socket (2628) | SSL has been shut down. | 2014-10-28 16:33:50 CTS FIX socket (2628) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:33:50 CTS FIX socket (2628) | Shutdown and closed. | 2014-10-28 16:33:50 CTS FIX: Logged out and disconnected. | 2014-10-28 16:33:50 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:33:50 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:33:50 CTS FIX: Disconnected. | 2014-10-28 16:33:50 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:33:50 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:33:53 CTS FIX - Firm: Phillip | 2014-10-28 16:33:53 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 74.201.6.106 | 2014-10-28 16:33:53 CTS FIX socket (2632) | Connected. | 2014-10-28 16:33:53 CTS FIX socket (2632) | Starting SSL connection. | 2014-10-28 16:33:53 CTS FIX socket (2632) | SSL connection established. | 2014-10-28 16:33:54 CTS FIX: Sending the Logon message. | 2014-10-28 16:33:54 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:33:54 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:33:54 CTS FIX socket (2632) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:33:54 CTS FIX socket (2632) | SSL has been shut down. | 2014-10-28 16:33:54 CTS FIX socket (2632) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:33:54 CTS FIX socket (2632) | Shutdown and closed. | 2014-10-28 16:33:54 CTS FIX: Logged out and disconnected. | 2014-10-28 16:33:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:33:54 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:33:54 CTS FIX: Disconnected. | 2014-10-28 16:33:54 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:33:54 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:33:57 CTS FIX - Firm: Phillip | 2014-10-28 16:33:57 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 74.201.6.106 | 2014-10-28 16:33:57 CTS FIX socket (2628) | Connected. | 2014-10-28 16:33:57 CTS FIX socket (2628) | Starting SSL connection. | 2014-10-28 16:33:57 CTS FIX socket (2628) | SSL connection established. | 2014-10-28 16:33:57 CTS FIX: Sending the Logon message. | 2014-10-28 16:33:57 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:33:57 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:33:57 CTS FIX socket (2628) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:33:57 CTS FIX socket (2628) | SSL has been shut down. | 2014-10-28 16:33:57 CTS FIX socket (2628) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:33:57 CTS FIX socket (2628) | Shutdown and closed. | 2014-10-28 16:33:57 CTS FIX: Logged out and disconnected. | 2014-10-28 16:33:57 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:33:57 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:33:57 CTS FIX: Disconnected. | 2014-10-28 16:33:57 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:33:57 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:34:00 CTS FIX - Firm: Phillip | 2014-10-28 16:34:00 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 74.201.6.106 | 2014-10-28 16:34:00 CTS FIX socket (2632) | Connected. | 2014-10-28 16:34:00 CTS FIX socket (2632) | Starting SSL connection. | 2014-10-28 16:34:00 CTS FIX socket (2632) | SSL connection established. | 2014-10-28 16:34:01 CTS FIX: Sending the Logon message. | 2014-10-28 16:34:01 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:34:01 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:34:01 CTS FIX socket (2632) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:34:01 CTS FIX socket (2632) | SSL has been shut down. | 2014-10-28 16:34:01 CTS FIX socket (2632) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:34:01 CTS FIX socket (2632) | Shutdown and closed. | 2014-10-28 16:34:01 CTS FIX: Logged out and disconnected. | 2014-10-28 16:34:01 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:34:01 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:34:01 CTS FIX: Disconnected. | 2014-10-28 16:34:01 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:34:01 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:34:04 CTS FIX - Firm: Phillip | 2014-10-28 16:34:04 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 208.116.215.102 | 2014-10-28 16:34:04 CTS FIX socket (2628) | Connected. | 2014-10-28 16:34:04 CTS FIX socket (2628) | Starting SSL connection. | 2014-10-28 16:34:04 CTS FIX socket (2628) | SSL connection established. | 2014-10-28 16:34:04 CTS FIX: Sending the Logon message. | 2014-10-28 16:34:04 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:34:04 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:34:04 CTS FIX socket (2628) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:34:04 CTS FIX socket (2628) | SSL has been shut down. | 2014-10-28 16:34:04 CTS FIX socket (2628) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:34:04 CTS FIX socket (2628) | Shutdown and closed. | 2014-10-28 16:34:04 CTS FIX: Logged out and disconnected. | 2014-10-28 16:34:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:34:04 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:34:04 CTS FIX: Disconnected. | 2014-10-28 16:34:04 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:34:04 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:34:07 CTS FIX - Firm: Phillip | 2014-10-28 16:34:07 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 208.116.215.102 | 2014-10-28 16:34:07 CTS FIX socket (2632) | Connected. | 2014-10-28 16:34:08 CTS FIX socket (2632) | Starting SSL connection. | 2014-10-28 16:34:08 CTS FIX socket (2632) | SSL connection established. | 2014-10-28 16:34:08 CTS FIX: Sending the Logon message. | 2014-10-28 16:34:08 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:34:08 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:34:08 CTS FIX socket (2632) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:34:08 CTS FIX socket (2632) | SSL has been shut down. | 2014-10-28 16:34:08 CTS FIX socket (2632) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:34:08 CTS FIX socket (2632) | Shutdown and closed. | 2014-10-28 16:34:08 CTS FIX: Logged out and disconnected. | 2014-10-28 16:34:08 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:34:08 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:34:08 CTS FIX: Disconnected. | 2014-10-28 16:34:08 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:34:08 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:34:11 CTS FIX - Firm: Phillip | 2014-10-28 16:34:11 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 208.116.215.102 | 2014-10-28 16:34:11 CTS FIX socket (488) | Connected. | 2014-10-28 16:34:11 CTS FIX socket (488) | Starting SSL connection. | 2014-10-28 16:34:11 CTS FIX socket (488) | SSL connection established. | 2014-10-28 16:34:11 CTS FIX: Sending the Logon message. | 2014-10-28 16:34:11 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:34:11 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:34:11 CTS FIX socket (488) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:34:11 CTS FIX socket (488) | SSL has been shut down. | 2014-10-28 16:34:11 CTS FIX socket (488) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:34:11 CTS FIX socket (488) | Shutdown and closed. | 2014-10-28 16:34:11 CTS FIX: Logged out and disconnected. | 2014-10-28 16:34:11 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:34:11 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:34:11 CTS FIX: Disconnected. | 2014-10-28 16:34:11 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:34:11 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:34:14 CTS FIX - Firm: Phillip | 2014-10-28 16:34:14 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 69.44.110.106 | 2014-10-28 16:34:15 CTS FIX socket (1236) | Connected. | 2014-10-28 16:34:15 CTS FIX socket (1236) | Starting SSL connection. | 2014-10-28 16:34:15 CTS FIX socket (1236) | SSL connection established. | 2014-10-28 16:34:15 CTS FIX: Sending the Logon message. | 2014-10-28 16:34:15 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:34:15 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:34:15 CTS FIX socket (1236) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:34:15 CTS FIX socket (1236) | SSL has been shut down. | 2014-10-28 16:34:15 CTS FIX socket (1236) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:34:15 CTS FIX socket (1236) | Shutdown and closed. | 2014-10-28 16:34:15 CTS FIX: Logged out and disconnected. | 2014-10-28 16:34:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:34:15 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:34:15 CTS FIX: Disconnected. | 2014-10-28 16:34:15 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:34:15 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:34:18 CTS FIX - Firm: Phillip | 2014-10-28 16:34:18 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 69.44.110.106 | 2014-10-28 16:34:18 CTS FIX socket (1956) | Connected. | 2014-10-28 16:34:18 CTS FIX socket (1956) | Starting SSL connection. | 2014-10-28 16:34:18 CTS FIX socket (1956) | SSL connection established. | 2014-10-28 16:34:18 CTS FIX: Sending the Logon message. | 2014-10-28 16:34:18 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:34:19 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:34:19 CTS FIX socket (1956) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:34:19 CTS FIX socket (1956) | SSL has been shut down. | 2014-10-28 16:34:19 CTS FIX socket (1956) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:34:19 CTS FIX socket (1956) | Shutdown and closed. | 2014-10-28 16:34:19 CTS FIX: Logged out and disconnected. | 2014-10-28 16:34:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:34:19 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:34:19 CTS FIX: Disconnected. | 2014-10-28 16:34:19 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:34:19 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:34:22 CTS FIX - Firm: Phillip | 2014-10-28 16:34:22 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 69.44.110.106 | 2014-10-28 16:34:22 CTS FIX socket (1156) | Connected. | 2014-10-28 16:34:22 CTS FIX socket (1156) | Starting SSL connection. | 2014-10-28 16:34:22 CTS FIX socket (1156) | SSL connection established. | 2014-10-28 16:34:22 CTS FIX: Sending the Logon message. | 2014-10-28 16:34:22 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:34:22 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:34:22 CTS FIX socket (1156) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:34:22 CTS FIX socket (1156) | SSL has been shut down. | 2014-10-28 16:34:22 CTS FIX socket (1156) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:34:22 CTS FIX socket (1156) | Shutdown and closed. | 2014-10-28 16:34:22 CTS FIX: Logged out and disconnected. | 2014-10-28 16:34:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:34:22 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:34:22 CTS FIX: Disconnected. | 2014-10-28 16:34:22 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:34:22 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:34:25 CTS FIX - Firm: Phillip | 2014-10-28 16:34:25 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 208.116.215.102 | 2014-10-28 16:34:25 CTS FIX socket (1164) | Connected. | 2014-10-28 16:34:25 CTS FIX socket (1164) | Starting SSL connection. | 2014-10-28 16:34:25 CTS FIX socket (1164) | SSL connection established. | 2014-10-28 16:34:25 CTS FIX: Sending the Logon message. | 2014-10-28 16:34:26 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:34:26 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:34:26 CTS FIX socket (1164) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:34:26 CTS FIX socket (1164) | SSL has been shut down. | 2014-10-28 16:34:26 CTS FIX socket (1164) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:34:26 CTS FIX socket (1164) | Shutdown and closed. | 2014-10-28 16:34:26 CTS FIX: Logged out and disconnected. | 2014-10-28 16:34:26 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:34:26 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:34:26 CTS FIX: Disconnected. | 2014-10-28 16:34:26 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:34:26 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:34:29 CTS FIX - Firm: Phillip | 2014-10-28 16:34:29 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 208.116.215.102 | 2014-10-28 16:34:29 CTS FIX socket (1156) | Connected. | 2014-10-28 16:34:29 CTS FIX socket (1156) | Starting SSL connection. | 2014-10-28 16:34:29 CTS FIX socket (1156) | SSL connection established. | 2014-10-28 16:34:29 CTS FIX: Sending the Logon message. | 2014-10-28 16:34:29 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:34:29 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:34:29 CTS FIX socket (1156) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:34:29 CTS FIX socket (1156) | SSL has been shut down. | 2014-10-28 16:34:29 CTS FIX socket (1156) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:34:29 CTS FIX socket (1156) | Shutdown and closed. | 2014-10-28 16:34:29 CTS FIX: Logged out and disconnected. | 2014-10-28 16:34:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:34:29 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:34:29 CTS FIX: Disconnected. | 2014-10-28 16:34:29 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:34:29 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:34:32 CTS FIX - Firm: Phillip | 2014-10-28 16:34:32 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 208.116.215.102 | 2014-10-28 16:34:32 CTS FIX socket (984) | Connected. | 2014-10-28 16:34:32 CTS FIX socket (984) | Starting SSL connection. | 2014-10-28 16:34:32 CTS FIX socket (984) | SSL connection established. | 2014-10-28 16:34:32 CTS FIX: Sending the Logon message. | 2014-10-28 16:34:32 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:34:33 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:34:33 CTS FIX socket (984) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:34:33 CTS FIX socket (984) | SSL has been shut down. | 2014-10-28 16:34:33 CTS FIX socket (984) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:34:33 CTS FIX socket (984) | Shutdown and closed. | 2014-10-28 16:34:33 CTS FIX: Logged out and disconnected. | 2014-10-28 16:34:33 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:34:33 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:34:33 CTS FIX: Disconnected. | 2014-10-28 16:34:33 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:34:33 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:34:36 CTS FIX - Firm: Phillip | 2014-10-28 16:34:36 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 69.44.110.106 | 2014-10-28 16:34:36 CTS FIX socket (988) | Connected. | 2014-10-28 16:34:36 CTS FIX socket (988) | Starting SSL connection. | 2014-10-28 16:34:36 CTS FIX socket (988) | SSL connection established. | 2014-10-28 16:34:36 CTS FIX: Sending the Logon message. | 2014-10-28 16:34:36 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:34:36 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:34:36 CTS FIX socket (988) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:34:36 CTS FIX socket (988) | SSL has been shut down. | 2014-10-28 16:34:36 CTS FIX socket (988) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:34:36 CTS FIX socket (988) | Shutdown and closed. | 2014-10-28 16:34:36 CTS FIX: Logged out and disconnected. | 2014-10-28 16:34:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:34:36 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:34:36 CTS FIX: Disconnected. | 2014-10-28 16:34:36 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:34:36 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:34:39 CTS FIX - Firm: Phillip | 2014-10-28 16:34:39 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 69.44.110.106 | 2014-10-28 16:34:39 CTS FIX socket (2224) | Connected. | 2014-10-28 16:34:39 CTS FIX socket (2224) | Starting SSL connection. | 2014-10-28 16:34:39 CTS FIX socket (2224) | SSL connection established. | 2014-10-28 16:34:39 CTS FIX: Sending the Logon message. | 2014-10-28 16:34:40 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:34:40 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:34:40 CTS FIX socket (2224) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:34:40 CTS FIX socket (2224) | SSL has been shut down. | 2014-10-28 16:34:40 CTS FIX socket (2224) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:34:40 CTS FIX socket (2224) | Shutdown and closed. | 2014-10-28 16:34:40 CTS FIX: Logged out and disconnected. | 2014-10-28 16:34:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:34:40 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:34:40 CTS FIX: Disconnected. | 2014-10-28 16:34:40 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:34:40 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:34:43 CTS FIX - Firm: Phillip | 2014-10-28 16:34:43 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 69.44.110.106 | 2014-10-28 16:34:43 CTS FIX socket (1172) | Connected. | 2014-10-28 16:34:43 CTS FIX socket (1172) | Starting SSL connection. | 2014-10-28 16:34:43 CTS FIX socket (1172) | SSL connection established. | 2014-10-28 16:34:43 CTS FIX: Sending the Logon message. | 2014-10-28 16:34:43 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:34:43 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:34:43 CTS FIX socket (1172) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:34:43 CTS FIX socket (1172) | SSL has been shut down. | 2014-10-28 16:34:43 CTS FIX socket (1172) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:34:43 CTS FIX socket (1172) | Shutdown and closed. | 2014-10-28 16:34:43 CTS FIX: Logged out and disconnected. | 2014-10-28 16:34:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:34:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:34:43 CTS FIX: Disconnected. | 2014-10-28 16:34:43 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:34:43 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:34:46 CTS FIX - Firm: Phillip | 2014-10-28 16:34:46 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 69.44.110.106 | 2014-10-28 16:34:46 CTS FIX socket (2224) | Connected. | 2014-10-28 16:34:46 CTS FIX socket (2224) | Starting SSL connection. | 2014-10-28 16:34:46 CTS FIX socket (2224) | SSL connection established. | 2014-10-28 16:34:46 CTS FIX: Sending the Logon message. | 2014-10-28 16:34:47 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:34:47 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:34:47 CTS FIX socket (2224) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:34:47 CTS FIX socket (2224) | SSL has been shut down. | 2014-10-28 16:34:47 CTS FIX socket (2224) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:34:47 CTS FIX socket (2224) | Shutdown and closed. | 2014-10-28 16:34:47 CTS FIX: Logged out and disconnected. | 2014-10-28 16:34:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:34:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:34:47 CTS FIX: Disconnected. | 2014-10-28 16:34:47 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:34:47 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:34:50 CTS FIX - Firm: Phillip | 2014-10-28 16:34:50 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 69.44.110.106 | 2014-10-28 16:34:50 CTS FIX socket (1172) | Connected. | 2014-10-28 16:34:50 CTS FIX socket (1172) | Starting SSL connection. | 2014-10-28 16:34:50 CTS FIX socket (1172) | SSL connection established. | 2014-10-28 16:34:50 CTS FIX: Sending the Logon message. | 2014-10-28 16:34:50 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:34:50 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:34:50 CTS FIX socket (1172) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:34:50 CTS FIX socket (1172) | SSL has been shut down. | 2014-10-28 16:34:50 CTS FIX socket (1172) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:34:50 CTS FIX socket (1172) | Shutdown and closed. | 2014-10-28 16:34:50 CTS FIX: Logged out and disconnected. | 2014-10-28 16:34:50 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:34:50 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:34:50 CTS FIX: Disconnected. | 2014-10-28 16:34:50 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:34:50 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:34:53 CTS FIX - Firm: Phillip | 2014-10-28 16:34:53 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 69.44.110.106 | 2014-10-28 16:34:53 CTS FIX socket (2224) | Connected. | 2014-10-28 16:34:53 CTS FIX socket (2224) | Starting SSL connection. | 2014-10-28 16:34:53 CTS FIX socket (2224) | SSL connection established. | 2014-10-28 16:34:53 CTS FIX: Sending the Logon message. | 2014-10-28 16:34:54 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:34:54 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:34:54 CTS FIX socket (2224) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:34:54 CTS FIX socket (2224) | SSL has been shut down. | 2014-10-28 16:34:54 CTS FIX socket (2224) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:34:54 CTS FIX socket (2224) | Shutdown and closed. | 2014-10-28 16:34:54 CTS FIX: Logged out and disconnected. | 2014-10-28 16:34:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:34:54 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:34:54 CTS FIX: Disconnected. | 2014-10-28 16:34:54 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:34:54 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:34:57 CTS FIX - Firm: Phillip | 2014-10-28 16:34:57 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 74.201.6.106 | 2014-10-28 16:34:58 CTS FIX socket (1172) | Connected. | 2014-10-28 16:34:58 CTS FIX socket (1172) | Starting SSL connection. | 2014-10-28 16:34:58 CTS FIX socket (1172) | SSL connection established. | 2014-10-28 16:34:58 CTS FIX: Sending the Logon message. | 2014-10-28 16:34:58 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:34:58 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:34:58 CTS FIX socket (1172) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:34:58 CTS FIX socket (1172) | SSL has been shut down. | 2014-10-28 16:34:58 CTS FIX socket (1172) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:34:58 CTS FIX socket (1172) | Shutdown and closed. | 2014-10-28 16:34:58 CTS FIX: Logged out and disconnected. | 2014-10-28 16:34:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:34:58 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:34:58 CTS FIX: Disconnected. | 2014-10-28 16:34:58 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:34:58 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:35:01 CTS FIX - Firm: Phillip | 2014-10-28 16:35:01 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 74.201.6.106 | 2014-10-28 16:35:01 CTS FIX socket (2224) | Connected. | 2014-10-28 16:35:01 CTS FIX socket (2224) | Starting SSL connection. | 2014-10-28 16:35:01 CTS FIX socket (2224) | SSL connection established. | 2014-10-28 16:35:01 CTS FIX: Sending the Logon message. | 2014-10-28 16:35:02 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:35:02 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:35:02 CTS FIX socket (2224) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:35:02 CTS FIX socket (2224) | SSL has been shut down. | 2014-10-28 16:35:02 CTS FIX socket (2224) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:35:02 CTS FIX socket (2224) | Shutdown and closed. | 2014-10-28 16:35:02 CTS FIX: Logged out and disconnected. | 2014-10-28 16:35:02 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:35:02 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:35:02 CTS FIX: Disconnected. | 2014-10-28 16:35:02 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:35:02 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:35:05 CTS FIX - Firm: Phillip | 2014-10-28 16:35:05 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 74.201.6.106 | 2014-10-28 16:35:05 CTS FIX socket (1172) | Connected. | 2014-10-28 16:35:05 CTS FIX socket (1172) | Starting SSL connection. | 2014-10-28 16:35:05 CTS FIX socket (1172) | SSL connection established. | 2014-10-28 16:35:05 CTS FIX: Sending the Logon message. | 2014-10-28 16:35:05 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:35:05 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:35:05 CTS FIX socket (1172) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:35:05 CTS FIX socket (1172) | SSL has been shut down. | 2014-10-28 16:35:05 CTS FIX socket (1172) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:35:05 CTS FIX socket (1172) | Shutdown and closed. | 2014-10-28 16:35:05 CTS FIX: Logged out and disconnected. | 2014-10-28 16:35:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:35:05 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:35:05 CTS FIX: Disconnected. | 2014-10-28 16:35:05 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:35:05 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:35:08 CTS FIX - Firm: Phillip | 2014-10-28 16:35:08 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 74.201.6.106 | 2014-10-28 16:35:08 CTS FIX socket (2224) | Connected. | 2014-10-28 16:35:08 CTS FIX socket (2224) | Starting SSL connection. | 2014-10-28 16:35:08 CTS FIX socket (2224) | SSL connection established. | 2014-10-28 16:35:09 CTS FIX: Sending the Logon message. | 2014-10-28 16:35:09 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:35:09 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:35:09 CTS FIX socket (2224) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:35:09 CTS FIX socket (2224) | SSL has been shut down. | 2014-10-28 16:35:09 CTS FIX socket (2224) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:35:09 CTS FIX socket (2224) | Shutdown and closed. | 2014-10-28 16:35:09 CTS FIX: Logged out and disconnected. | 2014-10-28 16:35:09 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:35:09 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:35:09 CTS FIX: Disconnected. | 2014-10-28 16:35:09 Will reconnect to the server in 3.0 minutes Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:35:09 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:38:09 CTS FIX - Firm: Phillip | 2014-10-28 16:38:09 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 69.44.110.106 | 2014-10-28 16:38:09 CTS FIX socket (2148) | Connected. | 2014-10-28 16:38:09 CTS FIX socket (2148) | Starting SSL connection. | 2014-10-28 16:38:09 CTS FIX socket (2148) | SSL connection established. | 2014-10-28 16:38:09 CTS FIX: Sending the Logon message. | 2014-10-28 16:38:09 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:38:09 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:38:09 CTS FIX socket (2148) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:38:09 CTS FIX socket (2148) | SSL has been shut down. | 2014-10-28 16:38:09 CTS FIX socket (2148) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:38:09 CTS FIX socket (2148) | Shutdown and closed. | 2014-10-28 16:38:09 CTS FIX: Logged out and disconnected. | 2014-10-28 16:38:09 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:38:09 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:38:09 CTS FIX: Disconnected. | 2014-10-28 16:38:09 Will reconnect to the server in 3.0 minutes Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:38:09 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:41:09 CTS FIX - Firm: Phillip | 2014-10-28 16:41:09 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 208.116.215.102 | 2014-10-28 16:41:10 CTS FIX socket (488) | Connected. | 2014-10-28 16:41:10 CTS FIX socket (488) | Starting SSL connection. | 2014-10-28 16:41:10 CTS FIX socket (488) | SSL connection established. | 2014-10-28 16:41:10 CTS FIX: Sending the Logon message. | 2014-10-28 16:41:10 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:41:10 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:41:10 CTS FIX socket (488) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:41:10 CTS FIX socket (488) | SSL has been shut down. | 2014-10-28 16:41:10 CTS FIX socket (488) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:41:10 CTS FIX socket (488) | Shutdown and closed. | 2014-10-28 16:41:10 CTS FIX: Logged out and disconnected. | 2014-10-28 16:41:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:41:10 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:41:10 CTS FIX: Disconnected. | 2014-10-28 16:41:10 Will reconnect to the server in 3.0 minutes Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:41:10 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:44:10 CTS FIX - Firm: Phillip | 2014-10-28 16:44:10 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 74.201.6.106 | 2014-10-28 16:44:10 CTS FIX socket (1148) | Connected. | 2014-10-28 16:44:10 CTS FIX socket (1148) | Starting SSL connection. | 2014-10-28 16:44:10 CTS FIX socket (1148) | SSL connection established. | 2014-10-28 16:44:10 CTS FIX: Sending the Logon message. | 2014-10-28 16:44:11 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:44:11 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:44:11 CTS FIX socket (1148) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:44:11 CTS FIX socket (1148) | SSL has been shut down. | 2014-10-28 16:44:11 CTS FIX socket (1148) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:44:11 CTS FIX socket (1148) | Shutdown and closed. | 2014-10-28 16:44:11 CTS FIX: Logged out and disconnected. | 2014-10-28 16:44:11 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:44:11 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:44:11 CTS FIX: Disconnected. | 2014-10-28 16:44:11 Will reconnect to the server in 3.0 minutes Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:44:11 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:47:11 CTS FIX - Firm: Phillip | 2014-10-28 16:47:11 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 74.201.6.106 | 2014-10-28 16:47:11 CTS FIX socket (708) | Connected. | 2014-10-28 16:47:11 CTS FIX socket (708) | Starting SSL connection. | 2014-10-28 16:47:11 CTS FIX socket (708) | SSL connection established. | 2014-10-28 16:47:11 CTS FIX: Sending the Logon message. | 2014-10-28 16:47:11 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:47:11 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:47:11 CTS FIX socket (708) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:47:11 CTS FIX socket (708) | SSL has been shut down. | 2014-10-28 16:47:11 CTS FIX socket (708) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:47:11 CTS FIX socket (708) | Shutdown and closed. | 2014-10-28 16:47:11 CTS FIX: Logged out and disconnected. | 2014-10-28 16:47:11 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:47:11 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:47:11 CTS FIX: Disconnected. | 2014-10-28 16:47:11 Will reconnect to the server in 3.0 minutes Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:47:11 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:50:11 CTS FIX - Firm: Phillip | 2014-10-28 16:50:11 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 69.44.110.106 | 2014-10-28 16:50:11 CTS FIX socket (2224) | Connected. | 2014-10-28 16:50:11 CTS FIX socket (2224) | Starting SSL connection. | 2014-10-28 16:50:11 CTS FIX socket (2224) | SSL connection established. | 2014-10-28 16:50:12 CTS FIX: Sending the Logon message. | 2014-10-28 16:50:12 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:50:12 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:50:12 CTS FIX socket (2224) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:50:12 CTS FIX socket (2224) | SSL has been shut down. | 2014-10-28 16:50:12 CTS FIX socket (2224) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:50:12 CTS FIX socket (2224) | Shutdown and closed. | 2014-10-28 16:50:12 CTS FIX: Logged out and disconnected. | 2014-10-28 16:50:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:50:12 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:50:12 CTS FIX: Disconnected. | 2014-10-28 16:50:12 Will reconnect to the server in 3.0 minutes Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:50:12 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:53:12 CTS FIX - Firm: Phillip | 2014-10-28 16:53:12 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 69.44.110.106 | 2014-10-28 16:53:12 CTS FIX socket (1116) | Connected. | 2014-10-28 16:53:12 CTS FIX socket (1116) | Starting SSL connection. | 2014-10-28 16:53:12 CTS FIX socket (1116) | SSL connection established. | 2014-10-28 16:53:12 CTS FIX: Sending the Logon message. | 2014-10-28 16:53:12 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:53:12 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:53:12 CTS FIX socket (1116) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:53:12 CTS FIX socket (1116) | SSL has been shut down. | 2014-10-28 16:53:12 CTS FIX socket (1116) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:53:12 CTS FIX socket (1116) | Shutdown and closed. | 2014-10-28 16:53:12 CTS FIX: Logged out and disconnected. | 2014-10-28 16:53:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:53:12 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:53:12 CTS FIX: Disconnected. | 2014-10-28 16:53:12 Will reconnect to the server in 3.0 minutes Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:53:12 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:56:12 CTS FIX - Firm: Phillip | 2014-10-28 16:56:12 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 208.116.215.102 | 2014-10-28 16:56:13 CTS FIX socket (1120) | Connected. | 2014-10-28 16:56:13 CTS FIX socket (1120) | Starting SSL connection. | 2014-10-28 16:56:13 CTS FIX socket (1120) | SSL connection established. | 2014-10-28 16:56:13 CTS FIX: Sending the Logon message. | 2014-10-28 16:56:13 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:56:13 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:56:13 CTS FIX socket (1120) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:56:13 CTS FIX socket (1120) | SSL has been shut down. | 2014-10-28 16:56:13 CTS FIX socket (1120) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:56:13 CTS FIX socket (1120) | Shutdown and closed. | 2014-10-28 16:56:13 CTS FIX: Logged out and disconnected. | 2014-10-28 16:56:13 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:56:13 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:56:13 CTS FIX: Disconnected. | 2014-10-28 16:56:13 Will reconnect to the server in 3.0 minutes Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:56:13 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 16:59:13 CTS FIX - Firm: Phillip | 2014-10-28 16:59:13 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 208.116.215.102 | 2014-10-28 16:59:13 CTS FIX socket (988) | Connected. | 2014-10-28 16:59:13 CTS FIX socket (988) | Starting SSL connection. | 2014-10-28 16:59:13 CTS FIX socket (988) | SSL connection established. | 2014-10-28 16:59:13 CTS FIX: Sending the Logon message. | 2014-10-28 16:59:14 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 16:59:14 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 16:59:14 CTS FIX socket (988) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 16:59:14 CTS FIX socket (988) | SSL has been shut down. | 2014-10-28 16:59:14 CTS FIX socket (988) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 16:59:14 CTS FIX socket (988) | Shutdown and closed. | 2014-10-28 16:59:14 CTS FIX: Logged out and disconnected. | 2014-10-28 16:59:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 16:59:14 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 16:59:14 CTS FIX: Disconnected. | 2014-10-28 16:59:14 Will reconnect to the server in 3.0 minutes Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 16:59:14 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 17:02:14 CTS FIX - Firm: Phillip | 2014-10-28 17:02:14 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 74.201.6.106 | 2014-10-28 17:02:14 CTS FIX socket (2432) | Connected. | 2014-10-28 17:02:14 CTS FIX socket (2432) | Starting SSL connection. | 2014-10-28 17:02:14 CTS FIX socket (2432) | SSL connection established. | 2014-10-28 17:02:14 CTS FIX: Sending the Logon message. | 2014-10-28 17:02:14 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 17:02:14 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 17:02:14 CTS FIX socket (2432) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 17:02:14 CTS FIX socket (2432) | SSL has been shut down. | 2014-10-28 17:02:14 CTS FIX socket (2432) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 17:02:14 CTS FIX socket (2432) | Shutdown and closed. | 2014-10-28 17:02:14 CTS FIX: Logged out and disconnected. | 2014-10-28 17:02:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 17:02:14 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 17:02:14 CTS FIX: Disconnected. | 2014-10-28 17:02:14 Will reconnect to the server in 3.0 minutes Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 17:02:14 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 17:05:14 CTS FIX - Firm: Phillip | 2014-10-28 17:05:14 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 208.116.215.102 | 2014-10-28 17:05:14 CTS FIX socket (2372) | Connected. | 2014-10-28 17:05:14 CTS FIX socket (2372) | Starting SSL connection. | 2014-10-28 17:05:14 CTS FIX socket (2372) | SSL connection established. | 2014-10-28 17:05:15 CTS FIX: Sending the Logon message. | 2014-10-28 17:05:15 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 17:05:15 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 17:05:15 CTS FIX socket (2372) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 17:05:15 CTS FIX socket (2372) | SSL has been shut down. | 2014-10-28 17:05:15 CTS FIX socket (2372) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 17:05:15 CTS FIX socket (2372) | Shutdown and closed. | 2014-10-28 17:05:15 CTS FIX: Logged out and disconnected. | 2014-10-28 17:05:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 17:05:15 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 17:05:15 CTS FIX: Disconnected. | 2014-10-28 17:05:15 Will reconnect to the server in 3.0 minutes Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 17:05:15 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-10-28 17:08:15 CTS FIX - Firm: Phillip | 2014-10-28 17:08:15 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 208.116.215.102 | 2014-10-28 17:08:15 CTS FIX socket (984) | Connected. | 2014-10-28 17:08:15 CTS FIX socket (984) | Starting SSL connection. | 2014-10-28 17:08:15 CTS FIX socket (984) | SSL connection established. | 2014-10-28 17:08:15 CTS FIX: Sending the Logon message. | 2014-10-28 17:08:15 CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. | 2014-10-28 17:08:16 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-10-28 17:08:16 CTS FIX socket (984) | SSL shutdown indicates not able to send 'close notify'. | 2014-10-28 17:08:16 CTS FIX socket (984) | SSL has been shut down. | 2014-10-28 17:08:16 CTS FIX socket (984) | SSL object has been freed. SSL state is now disconnected. | 2014-10-28 17:08:16 CTS FIX socket (984) | Shutdown and closed. | 2014-10-28 17:08:16 CTS FIX: Logged out and disconnected. | 2014-10-28 17:08:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-28 17:08:16 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-28 17:08:16 CTS FIX: Disconnected. | 2014-10-28 17:08:16 Will reconnect to the server in 3.0 minutes Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-28 17:08:16 |
[2014-10-28 22:38:25] |
MMX - Posts: 119 |
OK! I'm up and running, just had to complete the CTS setup page.
[2014-10-28 22:59:10] |
Yes. That is what needed to be done: CTS FIX: Received a Logout message. Text = The user has not completed the market data setup and should login to www.t4login.com and complete the setup page. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
