Date/Time: Wed, 30 Oct 2024 22:55:57 +0000
Charting IB Symbols
View Count: 1037
[2014-10-23 10:19:50]
User80177 - Posts: 29
Would appreciate advise on the flwg:
1. I subscribed to IB for the DAX Cash index (IB symbol DAX) and DJSTOXX50 index (IB symbol ERTX50). I have problems displaying these symbols in SC.
For DAX, I used symbol DAX-I-DTB from the SC\File\Find Symbol\InteractiveBrokers Instance\IB Index. The SC chart displays intraday bars correctly but does not update in real-time.
For DJSTOXX50 index, I could not find the symbol in SC\Find Symbol.
2. I have two separate installs of SC. One is ATChart and another for IB with a separate subscription. The data sharing between the two instances are working well but I do have a couple of questions;
a) The Chart Settings/Trade and Current Quote Symbol is occasionally "lost" after restarting SC or when I "Connect" to the data service. And, sometimes, the Chart Settings/Symbol changes to the symbol of the Data/Trade Service Settings/Service that is set.
b) Currently, my two installs are sharing a common data folder. I seem to recall reading recently that each SC installation should use its own Data folder, that sharing data folders can cause problems. If so, please point me to the article.
[2014-10-24 08:31:00]
Contact IB about this and also refer to help topic 3:
Http://www.sierrachart.com/index.php?page=doc/helpdetails3.html
We cannot find either of these symbols through an IB symbol search:
DJSTOXX50
ERTX50
This could only happen if you are you linking charts by symbol or using a quote board and linking it to a chart, and the symbol of the chart changes. Or you have enabled Chart >> Chart Settings >>Automatically Rollover Futures Symbol.
Do not do this! Refer to:
http://www.sierrachart.com/index.php?page=doc/MultipleServices.html
