Date/Time: Wed, 27 Nov 2024 18:49:09 +0000
auto TLs on CumDelta?
View Count: 1194
[2014-10-01 05:21:52] |
jivetrader - Posts: 410 |
please explain why there are auto trendlines on my CumDelta chart, and how to get rid of them. thank you.
CD TLs.png / V - Attached On 2014-10-01 05:21:25 UTC - Size: 64.1 KB - 365 views |
[2014-10-01 06:00:47] |
Obviously because you put them there.
[2014-10-01 07:04:03] |
is this a joke? if you don't have something helpful to add then please refrain. there are no auto-trendline studies on my chart. |
[2014-10-01 16:53:48] |
You are a much better position to make a determination as to where those lines came from than us, since you are the one using Sierra Chart and are interacting with it. Here are instructions to erase Chart Drawings: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ErasingChartDrawings We assume these are Chart Drawings. Unless they were put there by a study but this would not be a study from us. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
