Date/Time: Sun, 01 Nov 2026 04:39:25 +0000
[User Discussion] - Syntax in Alert for the study "Bar Time Duration"
View Count: 1869
[2014-10-01 04:11:48]
FFTrader - Posts: 180
I want to add a study alert such that if the study Bar Time Duration is above a threshold, it will color the bar, etc.
If for example, I want the condition to be "greater than 5 minutes and 00 seconds", I have the Study Alerts set as (as per the time format displayed):
= ID1.SG1>00:05:00
I also tried (as in 300 seconds):
= ID1.SG1>300
and also tried (as in 1/12 of an hour):
= ID1.SG1>0.08333
All of the above format yielded nothing or a syntax error. I also tried randomly putting in a number too.
What should be the correct syntax when referring to the Bar Time Duration study?
Date Time Of Last Edit: 2014-10-01 04:16:20
[2014-10-01 05:10:27]
Sawtooth - Posts: 4359
The output of the Bar Time Duration is in SerialDateTime format, without the date. This means you must convert the time to this format. One way is to use the TIMEVALUE spreadsheet function, like this:
=ID1.SG1>TIMEVALUE("00:05:00")
Another way to do it would be:
=ID1.SG1>5/1440
You had the correct idea to try 1/12 of an hour, but the format is based on a portion of a 24 hour day, not an hour. Since you want 5 minutes, and since there are 1440 minutes in a 24 hour day, 5/1440 gives you the correct value.
[2014-10-01 08:02:45]
Thanks!
