Date/Time: Mon, 16 Sep 2024 19:14:13 +0000
TPO value descriptors missing
View Count: 1015
[2014-10-01 00:12:49] |
jivetrader - Posts: 400 |
name labels for SG's are missing from right edge, please advise.
TPO value descriptors missing.png / V - Attached On 2014-10-01 00:12:38 UTC - Size: 185.66 KB - 314 views Attachment Deleted. |
[2014-10-01 02:21:37] |
Name labels are not supported. Only Value labels in this case. The documentation only makes reference to setting up Value labels. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
