Date/Time: Wed, 27 Nov 2024 18:32:04 +0000
BUG - Manage Chart Drawings
View Count: 933
[2014-09-29 13:49:48] |
FXDojiStar - Posts: 8 |
SC Crashes when you remove all the drawings and continue to delete. SC should prevent people deleting the symbol within Manage Chart Drawings function.
[2014-09-29 13:55:04] |
We will check on this.
[2014-09-29 17:10:18] |
Al SC Developer - Posts: 434 |
This should be addressed in ver 1197.
