Date/Time: Wed, 27 Nov 2024 18:34:00 +0000
Printig function
View Count: 923
[2014-09-29 07:23:35] |
FerroTrader - Posts: 70 |
Hello, is there a "Printing to an output window" fucntion in SC ? Thanks, AF |
[2014-09-29 13:49:02] |
Are you looking for this when using the Advanced Custom Study Interface and Language?
[2014-09-30 07:31:02] |
Hello, thank you for your replay. yes, I am looking for this when I code ACSIL. I would like a "printing output window" in which I can see the output of the functions SC uses. I have seen that "sc.AddMessageToLog(...)" function may help ! BTW, where can I find complete trading systems exemples ? thanks, AF |
[2014-09-30 15:31:41] |
For this, use sc.AddMessageToLog. You can find trading system examples here: http://www.sierrachart.com/index.php?page=doc/doc_ACSIL_ExampleTradingSystems.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
