Date/Time: Mon, 21 Apr 2025 13:05:42 +0000
When to update sierrachart.h?
View Count: 94
[2025-04-17 22:41:36]
User509533 - Posts: 73
When updating from the Zip installer, I only copy the SierraChart_64.exe file to my existing Sierra Chart folder. I do not copy the new sierrachart.h, SierraChartStudies_64.dll, or UserContributedStudies_64.dll files. So far, my existing or newly compiled custom .dll files continue to work without any issues using the older sierrachart.h, SierraChartStudies_64.dll, and UserContributedStudies_64.dll.
However, I understand that at some point it may become necessary to update these files. Would it be possible to include a note in the Change Log at the following link whenever an update to the .h or .dll files is required for compatibility with a new version?
https://www.sierrachart.com/index.php?page=doc/Whats_New.php
Thank you!
Date Time Of Last Edit: 2025-04-17 22:52:06
[2025-04-18 16:50:49]
User719512 - Posts: 309
You only need to update sierrachart.h for your local build when you use a function that requires a higher version number.
For example:
sierrachart.h
  // 2658
  int32_t (SCDLLCALL* GetSelectedUserDrawnDrawingFromChart)(const int ChartNumber, s_UseTool& r_ACSILChartDrawing);
If you want to use this function, it was introduced in v2658. So you need the header file that requires that minimum version as specified by SC_DLL_VERSION.
// SC_DLL_VERSION gets updated only when there have been changes to the DLL
// study interface. This will be set to the Sierra Chart version number
// that includes the changes made to the interface.
#define SC_DLL_VERSION 2748
