Date/Time: Mon, 21 Apr 2025 13:08:34 +0000
Opening Range Using Initial Balance Study.
View Count: 40
[2025-04-17 15:54:48] |
User750920 - Posts: 281 |
I am using the Initial Balance Study to draw lines on a chart for the Opening Range. I set the opening range for 30 seconds and applied it to a bar chart (5 minutes) Works fine. My problem is when I try to apply it to a TPO profile Chart it does not work. Everything is set the same as the bar chart but when the lines are drawn on the TPO chart they are drawn at the High and the Low of the day. Thanks |
[2025-04-17 16:15:35] |
John - SC Support - Posts: 39362 |
Refer to the following: Time Price Opportunity (TPO) Profile Charts: Using Other Studies on a TPO Chart As noted in the above, you would have to use a standard chart to get what you want and then overlay it to the TPO chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
