Date/Time: Wed, 27 Nov 2024 18:45:17 +0000
charts that are based on different data feed servers
View Count: 1246
[2014-09-28 12:46:26]
SKY - Posts: 45
assume i have to data deed sources (i.e. servers) where i have 2 sets of user-name/password
as i don't want to switch between servers (which means re-enter user/password again and again
does it mean that i need to have 2 installs of sierra at my PC ? each install will connect its
own server ... or there is another solution ?
in case the solution is 2 installs then should i expect any collisions at windows environment ?
tnx!
[2014-09-28 14:10:47]
Refer to the documentation here about this:
http://www.sierrachart.com/index.php?page=doc/doc_DataSourceSettings.html#SavingLoadingSettings
[2014-09-29 20:44:33]
SKY - Posts: 45
is there any free feed (of those compatible w/ SC) where I can get stocks/ETFs data
to be used at my SC platform ? (can't find one, even google finance doesn't provide
any info ... very strange)
many tnx
[2014-09-29 21:59:00]
Do you need just historical data for stocks and ETFs?
[2014-09-30 06:31:45]
SKY - Posts: 45
I need a feed of just stock & ETF
daily (1 min.) & historical
tnx
[2014-09-30 15:28:59]
Therefore, use the Sierra Chart Historical Data Service for the historical stock and ETF data:
http://www.sierrachart.com/index.php?page=doc/SierraChartHistoricalData.html
