Date/Time: Tue, 22 Apr 2025 05:07:46 +0000
windows and charts not staying in the arranged position and size
View Count: 65
[2025-04-14 19:19:19] |
User454729 - Posts: 22 |
Hi there, The position of the windows and the size of the charts do not re-open in the state which I saved them as. I have recently changed monitors have set up 3840 x 2160 resolution for 2 of my monitors and the regular 1920 x 1080 for the other 4 monitors. Previously when all monitors were at 1920 x 1080, I didn't experience this issue. Also, for reference, chrome didn't have any issue reopening in the saved state. |
[2025-04-14 19:31:16] |
Sierra_Chart Engineering - Posts: 19290 |
This is due to Microsoft Windows garbage. This is a fact. Also chrome does not use Windows functionality for its GUI. We have developed a workaround but it has its own issues: General Settings Window: Use Alternate Window Placement Method (Global Settings >> General Settings >> GUI >> Application GUI) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-04-14 19:33:08
