Date/Time: Wed, 27 Nov 2024 18:53:23 +0000
OHLC plus minus lines
View Count: 1002
[2014-09-28 01:25:38] |
User501307 - Posts: 1 |
Hello I am able to get the previous days high low and close drawn as horizontal lines without issue. What I am looking for is to draw horizontal lines that at Low +/- 1 ES point. So for the low of 1957.5, I would like a line at 1957.5 AND 1956.5. I want 2 lines draw so that I have a range represented. Is that possible? Thanks |
[2014-09-28 03:13:08] |
Sawtooth - Posts: 4120 |
Use the Bands/Envelope study, set the 'Based On' to the OHLC study. You could also use the Study Subgraph Add and Study Subgraph Subtract studies. Date Time Of Last Edit: 2014-09-29 02:11:05
[2014-09-29 02:10:35] |
Documentation for the studies mentioned in post #2 can be found here: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html Here is the documentation to base a study on another study: http://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#BasedOn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
