Date/Time: Tue, 22 Apr 2025 04:42:48 +0000
Flatten Order By Id
View Count: 51
[2025-04-14 10:03:02]
kam2001 - Posts: 86
Hi, please correct me if i am wrong but my understanding is that i can cancel an open order using an InternaOrderlId via sc.CancelOrder(InternalOrderID) but if i want to flatten a filled order i have to use sc.FlattenPosition() which will Flattens the current Trade Position for the Symbol. My question is that if i have two different filled orders for the same Symbol how can i only flatten just one of them, is there a function that also takes InternalOrderId and flatten the filled order with given Id. Thanks
[2025-04-14 15:14:46]
Sierra_Chart Engineering - Posts: 19290
This inherently does not make sense. If you want to reduce the quantity of a Trade Position, you simply submit an order to reduce the quantity of the Position by submitting an order of the opposite side of the Position, and of the quantity you want to reduce it by.
Inherently there is no concept of flattening a prior filled order. This concept does not exist.
Date Time Of Last Edit: 2025-04-14 15:15:43
