Date/Time: Tue, 22 Apr 2025 04:31:08 +0000
TPO profile - can I use same color for same time, even after split / merge?
View Count: 46
[2025-04-14 05:44:11]
joshtrader - Posts: 506
Is it possible to assign a color to a time, so that the 2:30 time (for example) will always be a certain color, regardless of split/merged profiles? As it stands, when I split a profile, both profiles will have the same starting color. I'd like to be able to split a profile and identify the time easily by the color, instead of having both profiles use the same starting color. Is it possible?
[2025-04-14 14:56:24]
Sierra_Chart Engineering - Posts: 19290
No, this is not supported and how this works is explained here:
Time Price Opportunity (TPO) Profile Charts: TPO Letter/Block Colors
