Date/Time: Tue, 15 Apr 2025 12:31:03 +0000
Issue with Delta Not Displaying on XAUUSD Daily Timeframe in Sierra Chart
View Count: 56
[2025-04-13 13:35:00]
User215654 - Posts: 1
Dear Sierra Chart Support,
I hope this message finds you well.
I am currently experiencing an issue while accessing the XAUUSD chart on the daily timeframe. Specifically, the delta values are not displaying correctly; each candle shows a delta of "0" consistently.
Could you kindly investigate this matter and advise on the cause or a possible resolution?
Looking forward to your assistance.
Best regards,
[2025-04-15 06:31:57]
Sierra_Chart Engineering - Posts: 19226
Most likely you are referring to the difference between Ask volume and Bid volume, but this data is not available on a Historical Daily chart.
You have to use an Intraday chart for this.:
Getting Started, Opening Charts and Basic Trading
