Date/Time: Mon, 14 Apr 2025 01:39:51 +0000
Foot print chart isn't showing any imbalances
View Count: 40
[2025-04-12 18:56:00]
User630927 - Posts: 1
I've been trying to set up my footprint chart, but it doesn't show me any of the imbalances. My bidxask are always at a larger number than zero on opening and closes of candles. Is there any way to change this I'm currently on the bar period type (days-min-secs) at 5 minutes which is the only one that would show me more than two numbers. On New York Time zone as well just none of my numbers are starting or ending with zero on the tail ends.
Private File
[2025-04-14 01:30:22]
drinkcodejava - Posts: 21
Make sure you set your imbalance percentage thresholds in the Numbers Bars study settings: Numbers Bars: Diagonal Comparison of Bid Volume and Ask Volume
There is an example section following the instructions: Numbers Bars: Diagonal Comparison Example
