Date/Time: Mon, 14 Apr 2025 02:18:17 +0000
changing a time based to renko chart
View Count: 45
[2025-04-12 14:21:23]
Siamak Yektafar - Posts: 4
i want to have a 4 hr chart but in renko .
i dont want to change the (BAR PERIOD VALUE) i need that to stay in 0-240-0 BUT the graph draw type be in RENKO.
when i do that the chart doesnt load correctly.
it only works if i also change the bar period type to Renko bars in ticks. BUT i dont know what a 4 hr chart renko brick size is.
can you plot a 4 hr chart with RENK bars showing in sierra?
[2025-04-13 20:10:15]
Sierra_Chart Engineering - Posts: 19166
This is not supported and we do not even know how this is possible.
You can certainly change the graph draw type to what you require:
Graph Draw Types
