Date/Time: Mon, 28 Apr 2025 11:10:08 +0000
How do I find out where my 'Stop loss order' was?
View Count: 105
[2025-04-12 01:49:13]
User100992 - Posts: 8
Hi.
Might be a silly question.
But how do I find out where my stop loss order was before it was cancelled?
Cancelled because the target order was filled, or the trade was flattened/cancelled.
I have looked in trade activity however seems to be a lot going on in there.
Any simple way of finding it?
Cheers
Joel
[2025-04-14 01:21:30]
drinkcodejava - Posts: 29
The Trade Activity tab of the Trade Activity Log is definitely the place to look. It helps if you know approximately what time it was canceled. You can narrow down the entries by using a time filter under DisplaySettings.
If it was canceled, use the Quick menu (or right-click anywhere in the table) and set Trade Activity Type > Orders. Then look for OrderType=Stop and OrderStatus=Canceled.
If the stop was actually triggered, you can set Trade Activity Type > Fills. This will be a shorter table and it will be easier to find.
Unfortunately the data cannot be sorted by clicking on column headers, but you can export to a tab-delimited txt file and import it to a spreadsheet program.
[2025-04-14 22:28:51]
Thank you.
Will have a look.
Cheers.
[2025-04-15 05:03:06]
Sierra_Chart Engineering - Posts: 19358
Yes you can definitely find this information in the Trade Activity Log:
Trade Activity Log: Viewing Historical Trade Activity
Date Time Of Last Edit: 2025-04-15 05:04:14
