Date/Time: Mon, 05 Oct 2026 00:11:39 +0000
[Programming Help] - Issue with Attached Orders – Common Stop Removed After First Target Hits
View Count: 2815
| [2025-04-11 23:54:36] |
| User720813 - Posts: 11 |
Hi Sierra Chart Support, I'm experiencing a problem when using attached orders with multiple profit targets and a common stop. Here's the situation: I'm submitting a 2-contract parent order using sc.BuyEntry() or sc.SellEntry() in ACSIL. The order includes: Target 1 at +30 points Target 2 at +75 points A single common stop loss at -20 points This is being submitted with a single parent order using: order.OrderQuantity = 2; order.AttachedOrderStop1Type = SCT_ORDERTYPE_STOP; order.Stop1Offset = 20.0f; order.AttachedOrderTarget1Type = SCT_ORDERTYPE_LIMIT; order.Target1Offset = 30.0f; order.AttachedOrderTarget2Type = SCT_ORDERTYPE_LIMIT; order.Target2Offset = 75.0f; The Problem: When Target 1 fills, the common stop is automatically canceled. This leaves Target 1 exposed with no protective stop. I do not want to stagger the entries or use separate parent orders — I need this to be handled as a single bracket with two targets and one stop that remains active after the first target fills. My Question: Is there a supported way within Sierra Chart to configure this behavior so that: One stop remains active for the second contract after the first target is hit? Or is this removal of the common stop after partial fill expected behavior? If there's a workaround, custom flag, or order configuration that will preserve the stop for the remaining contract, I’d greatly appreciate your guidance. Thank you, Adam |
| [2025-04-12 00:50:57] |
| Sierra_Chart Engineering - Posts: 25055 |
This is wrong for what you want to do: order.AttachedOrderStop1Type = SCT_ORDERTYPE_STOP; order.Stop1Offset = 20.0f; order.AttachedOrderTarget1Type = SCT_ORDERTYPE_LIMIT; order.Target1Offset = 30.0f; order.AttachedOrderTarget2Type = SCT_ORDERTYPE_LIMIT; order.Target2Offset = 75.0f; It needs to be: order.OCOGroup1Quantity = 1;
order.AttachedOrderTarget1Type = SCT_ORDERTYPE_LIMIT; order.Target1Offset = 30.0f; order.OCOGroup2Quantity = 1; order.AttachedOrderTarget2Type = SCT_ORDERTYPE_LIMIT; order.Target2Offset = 75.0f; order.StopAllOffset = 20.0f; order.AttachedOrderStopAllType = SCT_ORDERTYPE_STOP; Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
