Date/Time: Mon, 14 Apr 2025 01:49:47 +0000
Peaks Valley problem
View Count: 38
[2025-04-11 21:37:52] |
XL - Posts: 17 |
The VbP sensitivity lines for TPO chart Peaks and Valleys remain unchanged, even after adjusting the sensitivity. I'm using Version 2751 (64-bit). I am encountering this issue with two TPO charts. To avoid cluttering the charts, I currently have the setting set to "None." This setting has been intermittently problematic, so I tend to avoid making extensive changes to prevent disrupting the charts further. However, at this point, I am unable to get this setting to function correctly and need assistance. Before resorting to recreating the charts from scratch—which is quite time-consuming—are there any known issues with this setting or alternative solutions I could try? |
