Date/Time: Mon, 14 Apr 2025 01:49:47 +0000
AMP futures order allocation - accounts not showing in allocation accounts
View Count: 46
[2025-04-11 21:24:21] |
User664073 - Posts: 2 |
Hi - I have two accounts with AMP under the same SC account and with Teton. I'm trying to set up order allocation between the two accounts and both are showing in the available accounts dropdown, but the allocation account dropdown is empty. I've enabled order allocation and have tried selecting either account in the available accounts, but no accounts still show in the allocation account dropdown. Is there anything else I need to configure to make this work? One account is a personal account with AMP and the other is an LLC account - I'm not sure if this makes any difference? Thanks! |
[2025-04-11 22:17:24] |
Sierra_Chart Engineering - Posts: 19166 |
On the Order Allocation to Trade Accounts window the Available Accounts list at the top will have the same accounts listed that you see here: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-04-11 22:58:07] |
Thanks for the quick reply - I do see the two accounts listed in both the trade window and the 'available accounts (list)', but when I try to select the other account in 'Allocation Accounts (list)', the dropdown list is empty.
[2025-04-12 00:05:31] |
You first need to add the account to the Allocation Accounts list by pressing the Add button. Full Instructions are here: Order Allocation to Trade Accounts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
