Date/Time: Tue, 22 Apr 2025 04:59:06 +0000
Moved to windows 11- Sierra is very slow and my charts takes forever to load
View Count: 204
[2025-04-11 18:06:17] |
User447693 - Posts: 39 |
I have 2 computers, my chart on one computer with windows 10 loads decent. but the same chart on a windows 11 takes for ever to load. The setting on both computer for data services is same. I am lost of ideas. This is for the 1st instance). I installed sierra again still no help went to an older version still no help. The second instance cannot load fully. i have put the log for the second instance. thanks for you help Date Time Of Last Edit: 2025-04-11 18:43:42
[2025-04-14 15:08:31] |
Sierra_Chart Engineering - Posts: 19290 |
Refer to: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.48 - Basic Steps to Resolve Performance Issue in Sierra Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-04-14 15:23:57] |
I have paid for siearra and usage time and i just cannot load the charts. Its takes a very long time to load and NQ charts do not load at all
[2025-04-15 06:18:55] |
Follow through the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Improving Historical Intraday Data Downloading Performance Set the Intraday Data Storage Time Unit to 5 Seconds. Once this is done, delete the chart data files for the symbols you are using: Chart Data and Chart Data Files: Deleting a Chart Data File You will need to close your Chartbook first. Once this is done you can reopen your Chartbook. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-04-15 06:26:22
