Date/Time: Tue, 22 Apr 2025 04:48:05 +0000
Candlestick/ Bar Time Labeling
View Count: 65
[2025-04-11 14:29:38]
User885586 - Posts: 1
I am looking to find out if there is a way to have your chart label the time as the close of the candlestick/bar.
Currently it labels them for the start of the bar. I would like them to be labeled for the time that bar ends.
Example- an opening 3 minute 9:30 candle/bar is labeled as 9:30, then the next bar is labeled 9:33.
I would like the first candlestick/ bar to be labeled as 9:33, representing the three minutes of past price action in that bar.
Sorry if this is an easy fix/ already been answered but anything I search up came back with no results.
Date Time Of Last Edit: 2025-04-11 14:30:34
[2025-04-14 15:03:06]
Sierra_Chart Engineering - Posts: 19290
This is not supported. How this works is explained here:
Chart Session Times: Bar Starting Times
However, you can use this study:
Bar End Time
