Date/Time: Tue, 15 Apr 2025 12:27:59 +0000
footprint
View Count: 48
[2025-04-10 15:29:55] |
User847503 - Posts: 18 |
hi guys, I would like to know how I can add a diamond signal to my 5-minute footprint, where it is only triggered if the candle in total has more than 900 contracts and a delta greater than 100 either sell or buy, I will now show you a picture of my footprint to show you the settings I already have, if you could kindly guide me in what I need to do
[2025-04-10 15:35:09] |
John - SC Support - Posts: 39274 |
Use the "Color Bar Based on Alert Condition" study to do this. You need some way to get the delta of the bars to test against. The easiest way to do this is to add the "Numbers Bars Calculated Values" study to the chart. You can hide this study if you do not want to view it. The Alert condition itself will look like the following: =AND(V > 900, ABS(ID1.SG1) > 100) Where V is the Volume of the bar, ABS() is the Absolute Value function, ID1 is the ID of the Numbers Bars Calculated Values Study (or whatever study you are getting the Delta from) and SG1 is the first subgraph of the ID1 study. Refer to the following - in particular the section for "Drawing Arrows/Text or Other Styles at the High or Low of Bars": Color Bar Based on Alert Condition For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
