Date/Time: Tue, 15 Apr 2025 12:28:00 +0000
Chart tabs at bottom of chart is missing with latest update
View Count: 59
[2025-04-10 15:28:39]
User454729 - Posts: 22
Hi there, I used to be able to call up charts within a chartbook using the tabs at the bottom but it is now missing with the latest update. the MDI setting in global settings have already been set to Yes and to be shown at bottom.
[2025-04-10 18:31:29]
John - SC Support - Posts: 39274
Are you viewing multiple charts within the main window, and if so do you have the option for "Chart >> Show Title Bar" disabled?
If the above is true, then try setting the Title Bar to show and let us know if the tabs are displaying. If this does happen, then there is nothing we can do about it, as it is a Microsoft related issue.
Other things to try:
- Toggle the setting for "Global Settings >> General Settings >> Windows >> Use MDI Window Tabs" from Yes to No and then apply, and then from No to Yes and then Apply.
- Restart Sierra Chart and do not open your standard chartbooks (there is an option for not opening the chartbooks on the login screen). Then open a single chart and see if the tab is present. Then open a chartbook and see if the tabs show up.
[2025-04-14 13:52:40]
TonyCipriani - Posts: 25
Mine was working fine too but with the latest update as well, I had this same issue where the tabs of each chartbook were missing all of a sudden.
Changing the MDI window tab setting from Yes to no, restarting it, and then reverting it fixed it though.
[2025-04-14 14:53:01]
Sierra_Chart Engineering - Posts: 19226
Unlikely this is a problem within Sierra Chart. Most likely going to be an operating system level problem.
