Date/Time: Tue, 15 Apr 2025 12:27:59 +0000
Chart Study not updating on Trade DOM
View Count: 42
[2025-04-10 13:10:48]
CatsPajamas - Posts: 8
I created an opening range study using the High/Low for Time Period - Extended. I want to see the 30 second opening range from 8:30 when equities open. This populates and works well on the chart. However, I want this to pop up on the DOM immediately as it's drawing on the chart. So, on the DOM I did a Study/Price Overlay and added that study from the 30 second chart. I would expect this to start drawing on the DOM when it starts drawing on the chart. However, it seems to only pop up a few minutes later.
[2025-04-10 14:22:45]
John - SC Support - Posts: 39274
We just tested this and do not see any issue with how it is working.
We wonder if what you are seeing is due to the length of the line in the Trading DOM. The line will be very small at first, as it is being drawn on just the one "bar" in the Trading DOM. As time goes on, the lines stretch out over multiple bars are become more visible.
What we recommend in this case is to set the "Study/Price Overlay" Input for "Use Styles and Widths from Source Chart" to "No" and then set the "Draw Style" for the lines to be "Line at Last Bar Left to Right". This will make the line fully across the DOM so it is easier to see.
