Date/Time: Tue, 15 Apr 2025 12:25:30 +0000
Issue when updating SC
View Count: 53
[2025-04-10 01:27:07] |
User993440 - Posts: 20 |
Please see the log that was sent directly to you. Thanks |
[2025-04-10 13:56:13] |
John - SC Support - Posts: 39274 |
You are getting the following error: Windows error code 112: There is not enough space on the disk.
You are out of space on your drive where Sierra Chart is installed. You can follow these instructions to clear out data from Sierra Chart to clear some space, but you will need to see if there are other items you need to remove to make space - or get a larger drive: Chart Data and Chart Data Files: Cleaning Up Old and Unused Symbols for Efficiency For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
