Date/Time: Tue, 15 Apr 2025 12:25:31 +0000
Running 2 Sierra Charts on 2 Different Computers (One real-time / One delayed data)
View Count: 56
[2025-04-09 19:09:12]
mastadom - Posts: 17
I currently have the package 11 and real-time CME exchange data.
It looks like I cannnot run Sierra Charts from two different computers at the same time with one exchange data. The only way this is possible is to have an additional CME exchange data subscription as of my understanding.
Link: Denali Exchange Data Feed: Connections
My question is:
#1. Can I run Sierra Chart on real-time for one computer and another Sierra Chart with delayed data on another computer?
#2. If yes, which service should I select (under Global Settings -> Main Settings -> Current Selected Service) for the Delayed data version?
Thank you
[2025-04-09 19:48:36]
John - SC Support - Posts: 39274
1. Yes, you can do this. On the system where you want to get the delayed streaming data set "Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds" to "No". Select OK to close that window, then select "File >> Reconnect" to reconnect to the data feed and start getting the delayed data.
2. You need to be connected to "SC Data" or the "Trading Evaluator - Delayed" for the Current Selected Service.
Date Time Of Last Edit: 2025-04-09 19:49:13
