Date/Time: Mon, 21 Apr 2025 22:19:02 +0000
How to remove Chart Dom
View Count: 86
[2025-04-09 16:44:59]
TradingInDemand - Posts: 26
I want to remove all text and numbers from my chart DOM, leaving only the volume bars visible.
Also, is there a way to add custom volume profile studies to the chart DOM, similar to how they can be added to the regular DOM?
Thanks and I appreciate your work.
imageScreenshot 2025-04-09 114017.png / V - Attached On 2025-04-09 16:40:34 UTC - Size: 69.26 KB - 24 views
[2025-04-09 17:57:37]
John - SC Support - Posts: 39395
The only option for hiding the values in the DOM is to set a value for the "Only Display Market Depth Above/Equal Quantity" to a very high value. This only works for the Bid/Ask Market Depth columns and does not impact any other column. Refer to the following:
Chart Settings: Chart DOM/DOM Graph: Only Display Market Depth Above/Equal Quantity (Chart >> Chart Settings >> Market Depth menu)
We are not sure we understand the question. In particular, what do you mean by a "custom volume profile"? And we wonder if you are referring to the Trading DOM and not a Chart DOM.
We think what you may be asking is answered in the second paragraph here:
Volume By Price Study: Volume Graph Period Type
[2025-04-14 13:49:51]
I’d love the ability to display Volume Profile studies (like Session VP, Visible Bars VP, or custom Volume by Price profiles) directly within the Chart DOM interface — similar to how Bookmap shows volume next to the price ladder.
Right now, I can overlay Volume by Price studies on the chart, but they don’t render inside or beside the DOM ladder itself.
imageScreenshot 2025-04-14 083815.png / V - Attached On 2025-04-14 13:40:45 UTC - Size: 527.8 KB - 9 views
imageScreenshot 2025-04-14 083840.png / V - Attached On 2025-04-14 13:40:57 UTC - Size: 583.72 KB - 9 views
[2025-04-15 06:27:16]
Sierra_Chart Engineering - Posts: 19290
They will be displayed on the left side of the Trading DOM window. The Volume by Price study can be used on a Trading DOM.
