Date/Time: Tue, 15 Apr 2025 12:25:29 +0000
Delta Profile Only Showing when > 300
View Count: 53
[2025-04-09 15:47:24]
User970450 - Posts: 3
How do I hide the actual delta profile levels that do not exceed the threshold value.
For example, I only want them to show when they are above 300 otherwise to be hidden from the overall profile.
In the chart attached, I want to see the levels which have numbers on them (which exceed threshold), but don't want to see the rest.
https://www.sierrachart.com/image.php?Image=174421359417.png
[2025-04-09 17:32:56]
John - SC Support - Posts: 39274
Refer to the following:
Volume By Price Study: Volume Text Threshold
[2025-04-10 12:07:36]
Thank you, but I can't seem to get the result I want. Normally I figure this stuff out using your great documentation.
I have set:
Display Volume in Bars (ln46) : Ask Volume - Bid Volume
Volume Text Threshold (ln125) : 300
Volume profile bars that > 300 are showing the text, and ones that don't, don't have the text.
But I also want the bars with no text to just disappear so I can only see the big delta levels and not clutter the chart with the others.
[2025-04-10 14:14:32]
There is not support for hiding the actual bars themselves. Just the text.
