Date/Time: Tue, 15 Apr 2025 12:31:03 +0000
Change width of columns and text sizes of MBO data on Chart DOM
View Count: 48
[2025-04-09 14:19:09] |
R10 - Posts: 11 |
Hi, i have the trading chart mode ON and i customized the columns with the data i want, but i'm not able to make the columns a bit larger (adjust the width) and specially the MBO data font is too small. I've tried on the global settings-graphic settings on Font to change the DOM Quantities/sizes text but nothing happens. I've also googled and read the chart dom settings, but i can't seem to figure out how to do it. Could someone please help me out? Thanks in advance |
[2025-04-09 15:20:43] |
John - SC Support - Posts: 39274 |
To change the width of the columns refer to the following: Global Trade Settings Windows: Chart/Trade DOM Column Widths and Headers (Trade >> Customize Chart/Trade DOM Columns) The font of the MBO column is controlled through the setting for "DOM Quantities/Sizes" in the Fonts tab on the Graphics Settings window. If changing that item does not change the size of the quantities in the DOM, then you are probably adjusting the wrong Graphics Settings. There are both Global Graphics Settings and Chart Specific Graphics Settings. Refer to the following: Graphics Settings: Using Different Color and Graphics Settings for Specific Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-04-09 16:42:01] |
R10 - Posts: 11 |
Thank you Jon for the super quick reply. You were right, i was on the graphic settings "global", because i somehow read it everywhere i was looking into. I changed it now on the chart graphic settings and its working perfectly. Thanks again and have a nice day!
