Date/Time: Tue, 15 Apr 2025 14:29:11 +0000
Volume/DELTA bars at bottom of chart
View Count: 42
[2025-04-08 18:31:51]
Brightstone - Posts: 19
Hi, how do i add the DELTA volume bars at the bottom of my chart? i had them then they went away and i cant figure out how to put it back..
see screenshot
imageDELTA bars at bottom.png / V - Attached On 2025-04-08 18:08:49 UTC - Size: 939.75 KB - 10 views
[2025-04-08 18:50:58]
John - SC Support - Posts: 39275
You need to add the study you want. Refer to the following:
Chart Studies: Adding/Modifying Chart Studies
