Date/Time: Tue, 15 Apr 2025 12:33:28 +0000
ZigZag - bug using option 2 and # of bars before turn -- also feature request on ZigZag
View Count: 79
[2025-04-08 17:58:37] |
JohnR - User831573 - Posts: 330 |
I am using the ZigZag study. I have attached an image showing the price moving more than my point amount, but it was the 1st day after a LH top. If I increase the point movement amount to be larger that the price move, the erroneous point disappears. It seems the logic is using Move points OR Number of Bars instead of AND The feature request is to either allow % movement as an input for option 2, or allow # of bars movement on option 1. Micro ES - 1 min chart time it occurred is 12:31 today east US Thanks for your time to look into this. JohnR Date Time Of Last Edit: 2025-04-08 18:00:07
[2025-04-10 15:03:50] |
Sierra_Chart Engineering - Posts: 19226 |
We will not be spending any time on this. The source code is available and you can modify it to meet your requirements: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
