Date/Time: Wed, 27 Nov 2024 17:50:03 +0000
Numbers Bars calculations within the bar.
View Count: 879
[2014-09-27 08:24:28] |
2garin - Posts: 184 |
Hello support. Studying P&F bars noticed the discrepancy in the calculations of maximum values within a bar. |
ES.20141200.CME_Eq Rev. 6t #1 2014-09-27 19_14_54.880.png / V - Attached On 2014-09-27 08:17:36 UTC - Size: 107.05 KB - 358 views ES.20141200.CME_Eq Rev. 6t #1 2014-09-27 19_40_48.320.png / V - Attached On 2014-09-27 08:21:54 UTC - Size: 94.67 KB - 354 views |
[2014-09-27 21:34:58] |
We do not understand what it is you are trying to point out. Please keep this very simple and clear for us and post only one chart unless it is absolutely necessary to post more. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-28 00:27:40] |
Hello support. Your request to write briefly understood. Range bars marked with a question mark are wrong "Highlight Maximum Value In". |
[2014-09-28 03:53:23] |
From documentation: In the case of the Bid Vol x Ask Vol Text type, the price level with the maximum AskVolume for the Numbers Bar column is considered the maximum value and will be highlighted.
