Date/Time: Tue, 15 Apr 2025 14:21:35 +0000
Regarding NUMBER BARS, Volume and Volume Profile location
View Count: 71
[2025-04-07 16:35:16]
User246156 - Posts: 4
Hi guys, first and foremost I want to say that you are doing a fantastic job here.
I have a question regarding Bar Counts. I have set TEXT to Volume and BACKGROUND TYPE as Volume Profile
Is it possible to move the Volume Profile to the right side of the volume data? There is an option to move it on top of it (Right Aligned Volume Profile) but doing it that way doesn't allow reading of volume data.
I was wondering if there is a way to place the LEFT SIDE of the Volume Profile on the RIGHT SIDE of Volume.
If you don't have this functionality it would be a great thing to add to your charts.
Thanks in advance for your help!
[2025-04-07 16:43:17]
I have uploaded a file for practical purposes.
imageScreenshot 2025-04-07 123918.png / V - Attached On 2025-04-07 16:41:53 UTC - Size: 554.91 KB - 22 views
[2025-04-07 18:00:12]
DFromeaux - Posts: 12
On the column 1, show only the volume text without background.
On the column 2, show only the volume profile background without any text.
Set the "Single value text alignment" to the right.
And voilĂ  !
[2025-04-07 18:21:28]
John - SC Support - Posts: 39275
What DFromeaux states is the right idea. We are not sure which way you want the information aligned so play with the setup to get what you want.
[2025-04-07 20:40:26]
That's awesome, Thank you guys!
I am attaching a file just to show how it looks now, still need a some colors there but that is what I was trying to do.
Thank you very much!
imageScreenshot 2025-04-07 163744.png / V - Attached On 2025-04-07 20:39:59 UTC - Size: 306.89 KB - 19 views
