Date/Time: Tue, 15 Apr 2025 14:04:01 +0000
Can we automatically disable ATM or Trail Management by study after one order trigger?
View Count: 70
[2025-04-07 09:35:55] |
ISB3 - Posts: 14 |
Hi, I have a strategy that implies enter >3 Cts, then trailing 1 on short-term, 1 one mid-term, 1 on long-term, But if I use Trailing Management By Study and don't turn it off when price came close to my trigger price, the other stop-limit orders will be teleported to the short-term price trigger once the first is triggered. So I would like to automatically disable ATM or the Trail Management by study after one stop triggered. I tried to find if there is a way to do this, but don't find anything about this. |
[2025-04-07 14:59:56] |
John - SC Support - Posts: 39274 |
There is not a way to do this using the tool as it is. You would have to modify the source code to do what you want. In the end, it may be easier to just create a custom study to manage your orders in general, so you have complete control. Refer to the following: Automated Trading From an Advanced Custom Study https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-04-08 09:22:07] |
ISB3 - Posts: 14 |
For anyone interested about this feature, I modified the Trade Management By Study to turn off automatically. For now it just do this, but I will look later to automatically change the trailing to mid-term study if short-term triggered, and change the trailing to long-term study if mid-term triggered. Kind regards Date Time Of Last Edit: 2025-04-15 06:08:00
![]() Attachment Deleted. |
