Date/Time: Tue, 15 Apr 2025 13:44:48 +0000
Wrong trade account currency
View Count: 107
[2025-04-07 09:01:59] |
User715695 - Posts: 9 |
So i have EURO in my brokerage account but it converts it in USD in sierra chart. How can i change it to euro in trade account monitor and everywhere else for that matter ? Can't seem to find any post/option to fix this little annoyance. |
[2025-04-07 13:50:06] |
Sierra_Chart Engineering - Posts: 19226 |
It is not possible to change the currency in the Trade Account Monitor.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-04-08 07:51:54
[2025-04-07 15:21:49] |
So everything is in euro (the instrument, the money in my brokerage ) but the platform that has every option/feature under the sun doesn't support euro ? Not that this is much of a problem... but seems strange to have to trader euro stoxx for example but my account shows USD May i ask why ? Is there no demand for instruments denominated in Euro or something. Seems like an easy 'fix' |
[2025-04-08 07:52:55] |
What is the trading service you are using? We see you are using CQG? Only CQG would be able to control this. You need to contact them about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
