Date/Time: Mon, 14 Sep 2026 02:58:04 +0000
[Programming Help] - I have a programming question(TPO-Profile Chart)
View Count: 1083
[2025-04-07 08:51:26]
User134797 - Posts: 56
Good morning,
I have a programming question: I am using the following study chart “TPO Profile Chart”. This chart has a tab labeled “Subgraphs” with subgraphs named SG1, SG2, SG3, SG4, etc. I want to read all these SG’s via a script. I have created the script, but I am only able to read SG1, SG2, SG3, and SG4. Do you perhaps know why it is not possible to read the rest of the SG’s?
Thanks in advance for your support.
[2025-04-07 14:57:26]
John - SC Support - Posts: 47854
You should still be able to get the data from the other subgraphs, although most of them will be zeros, as many of the other subgraphs are only for coloring/width options and do not actually hold any data.
How are you accessing the subgraph data?
[2025-04-07 15:27:02]
This is the script.
#include <windows.h>
#include "sierrachart.h"
SCDLLName("TPO Exporter – Uitgebreid")
SCSFExport scsf_TPOExport(SCStudyInterfaceRef sc)
SCInputRef StartExport = sc.Input[0];
SCInputRef AantalDagen = sc.Input[1];
SCInputRef TPOStudyID = sc.Input[2];
if (sc.SetDefaults)
sc.GraphName = "TPO Exporter – Uitgebreid";
sc.AutoLoop = 0;
StartExport.Name = "Start Export";
StartExport.SetYesNo(false);
AantalDagen.Name = "Aantal dagen om te exporteren";
AantalDagen.SetInt(3);
AantalDagen.SetIntLimits(1, 30);
TPOStudyID.Name = "Study ID van TPO Chart";
TPOStudyID.SetStudyID(3); // pas aan indien anders
return;
if (!StartExport.GetYesNo())
return;
// 📅 Bestandsnaam per dag
SCDateTime vandaag = sc.CurrentSystemDateTime.GetDate();
char datumLabel[11];
snprintf(datumLabel, sizeof(datumLabel), "%04d-%02d-%02d",
vandaag.GetYear(), vandaag.GetMonth(), vandaag.GetDay());
SCString bestandPad = sc.DataFilesFolder();
bestandPad += "\\TPO_";
bestandPad += datumLabel;
bestandPad += ".csv";
FILE* bestand = fopen(bestandPad.GetChars(), "w");
if (!bestand)
SCString foutmelding = "❌ Kan bestand niet openen: ";
foutmelding += bestandPad;
sc.AddMessageToLog(foutmelding, 1);
return;
// ✅ Header met alles
fprintf(bestand, "Datum,Open,High,Low,Last,POC,VAH,VAL,POC_EXT,OpenMarker,LastT,InBalance,IBR1,OpenRange,PoorHL\n");
int tpoID = TPOStudyID.GetStudyID();
// ✅ Standaardvelden
SCFloatArray OpenArray, HighArray, LowArray, LastArray;
SCFloatArray VALArray, POCArray, VAHArray;
sc.GetStudyArrayUsingID(tpoID, 0, OpenArray);
sc.GetStudyArrayUsingID(tpoID, 1, HighArray);
sc.GetStudyArrayUsingID(tpoID, 2, LowArray);
sc.GetStudyArrayUsingID(tpoID, 3, LastArray);
sc.GetStudyArrayUsingID(tpoID, 15, VALArray);
sc.GetStudyArrayUsingID(tpoID, 16, POCArray);
sc.GetStudyArrayUsingID(tpoID, 17, VAHArray);
// ✅ Extra SG’s
SCFloatArray POC_Ext, OpenMarker, LastT, InBalance, IBR1, OpenRange, PoorHL;
sc.GetStudyArrayUsingID(tpoID, 14, POC_Ext);
sc.GetStudyArrayUsingID(tpoID, 18, OpenMarker);
sc.GetStudyArrayUsingID(tpoID, 20, LastT);
sc.GetStudyArrayUsingID(tpoID, 21, InBalance);
sc.GetStudyArrayUsingID(tpoID, 22, IBR1);
sc.GetStudyArrayUsingID(tpoID, 25, OpenRange);
sc.GetStudyArrayUsingID(tpoID, 34, PoorHL);
SCDateTime vorigeDatum = 0;
int geschreven = 0;
for (int i = sc.ArraySize - 1; i >= 0 && geschreven < AantalDagen.GetInt(); --i)
SCDateTime tijd = sc.BaseDateTimeIn.GetDate();
if (tijd == vorigeDatum)
continue;
vorigeDatum = tijd;
if (OpenArray == 0 && HighArray == 0 && LowArray == 0 && LastArray == 0)
continue;
char datumStr[11];
snprintf(datumStr, sizeof(datumStr), "%04d-%02d-%02d",
tijd.GetYear(), tijd.GetMonth(), tijd.GetDay());
fprintf(bestand, "%s,%.2f,%.2f,%.2f,%.2f,%.2f,%.2f,%.2f,%.2f,%.2f,%.2f,%.2f,%.2f,%.2f,%.2f\n",
datumStr,
OpenArray, HighArray, LowArray, LastArray,
POCArray, VAHArray, VALArray,
POC_Ext, OpenMarker, LastT, InBalance, IBR1, OpenRange, PoorHL);
++geschreven;
fclose(bestand);
SCString klaar = "✅ Uitgebreide TPO-export voltooid: ";
klaar += bestandPad;
sc.AddMessageToLog(klaar, 0);
[2025-04-07 23:29:08]
LudaTrades - Posts: 31
Your Open, High, Low, and Last subgraph indexes are correct and 0 based, but the rest do not seem to be, and you are grabbing color arrays and extension line styling anyway.
If you want the value area values, point of control, etc, try using sc.GetStudyProfileInformation.
[2025-04-17 23:25:56]
Stefan Alexandru Ilie - Posts: 4
n_ACSIL::s_StudyProfileInformation ProfileInfo;
float VAH = ProfileInfo.m_TPOValueAreaHigh;
float VAL = ProfileInfo.m_TPOValueAreaLow;
ProfileInfo.m_TPOPOCPrice << "|";
it works now, thank you !
[2025-04-22 15:48:01]
Thanks so far, but I still can't retrieve the Market Profile and Volume Profile correctly. What does work is getting the Open, High, Low, and Close – those are working, and I do need them too. Maybe someone else has managed to get it working. Thanks in advance!
