Date/Time: Wed, 27 Nov 2024 17:38:09 +0000
SELECT BARS ON WHICH TO DRAW A VOLUME PROFILE - VIDEO ATTACHED
View Count: 963
[2014-09-26 23:08:19] |
User75277 - Posts: 33 |
Maybe Sierra Chart does this, but I can not find out where and neither did anyone I asked. But, you might be interested in looking at this video to add a feature that most of your top competitors do not have. (video attached - I have a high res version, but I think the attached does the trick.) This feature allows selection of a group of bars on a chart to draw the volume profile for that group of bars selected. It is a WONDERFUL feature for combining a series of balance days to see one vol profile for the selected area. The video demo only shows a small portion of the char being selected, but it can work for almost any number of days. Date Time Of Last Edit: 2014-09-26 23:09:06
DEMO SELECT AND CREATE VOL PROFILE ON ANY NUMBER OF BARSsf4E.mp4 - Attached On 2014-09-26 23:07:34 UTC - Size: 1.3 MB - 467 views |
[2014-09-27 00:43:32] |
We did not watch the video. Sierra Chart has a Draw Volume Profile tool. It is documented here: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#DrawVolumeProfile Let us know if you need a trial extension so you can test it to see if it meets your requirements. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-27 00:43:42
[2014-09-27 19:39:28] |
Hi - Well I am happy that you have this tool. Yes, I would like a trial extension so I can test it to see if if fits my needs. I do not have package 5. I would like to get it but. I have ad a great deal of difficulty over the last month trying to get a spread sheet that worked previously --> working again. On Friday, I think I solved it but can not tell until Monday's log-in; this involved going back to version 1170 which is not current. I would like to try package 5 but not at the risk of having my spreadsheet stop working (if indeed the problem is fixed by version 1170). Would I be able to keep version 1170 and get package 5? Is there a special procedure needed for this? How would I do it? Thanks, in advance. Date Time Of Last Edit: 2014-09-27 19:40:10
[2014-09-28 03:57:09] |
We have added seven days to your account. Restart Sierra Chart. In regards to spreadsheets, make sure you use the version of Sierra Chart that has "Old Spreadsheets". You are able to download the version of Sierra Chart with New Spreadsheets or Old Spreadsheets through the Help menu. If you see no reference to Old or New, then you will get old spreadsheets. You can use any Sierra Chart version that you want. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-28 03:57:57
