Date/Time: Tue, 15 Apr 2025 12:27:59 +0000
Denali Exchange Data Feed Agreement - CME Group
View Count: 117
[2025-04-04 20:33:27]
User534443 - Posts: 2
Hi I can’t open my new chart book I bought it’s not opening all white page
imageimage.jpg / V - Attached On 2025-04-04 20:33:19 UTC - Size: 4.87 MB - 26 views
[2025-04-04 20:34:25]
John - SC Support - Posts: 39274
The symbol for that chart is not correct for the service you are currently connected to. With that Chartbook open, select "Edit >> Translate Symbols to Current Service".
[2025-04-10 02:54:11]
Hi I’m trying to open the footprint chart and I already have the 11 package and the Denali live data active but nothing is loading when I apply my chart book
Private File
[2025-04-10 08:19:00]
User135243 - Posts: 66
you're trying to open ESH25 (this contract already expired), try ESM25 and it should work
[2025-04-10 14:02:38]
We are not understanding the issue in post #3 with respect to the image. The image shows a normal chart. You state that you are trying to get a footprint chart. What exactly is the issue?
If you do not know how to use the Numbers Bars study, then refer to the following:
Numbers Bars: Step-By-Step Instructions
