Date/Time: Tue, 15 Apr 2025 14:21:34 +0000
Accessing past chart data --before 4-5-24?
View Count: 46
[2025-04-04 15:31:44] |
User121101 - Posts: 3 |
Hi SC, With the current market trend on the Emini S&P, the market is so low it has pushed the limit of the data I currently have in my chart. I'm trading currently the ESM25_FUT_CME, and I don't have any data in my charts that predates 4/5/24. Do you know how I may be able to access older data so that I can draw out composite value areas from those previous times? Thanks much. |
[2025-04-04 16:54:06] |
John - SC Support - Posts: 39275 |
Since Futures Contracts have a limited life, make sure you are using a Continuous Futures Contract. Refer to the following: Continuous Futures Contract Charts If the Continuous Futures Contract does not solve it immediately, then refer to the following: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
