Date/Time: Thu, 24 Apr 2025 12:39:00 +0000
how to stop the clock
View Count: 74
[2025-04-04 13:52:38] |
User716459 - Posts: 137 |
Please advise how to stop the clock, Sierra shows 7 minutes of delay.
[2025-04-04 15:22:15] |
John - SC Support - Posts: 39445 |
We do not know what you mean by "stop the clock" in reference to the delay showing. A delay of 7 minutes would typically mean that your computer clock is set differently from the exchange clock by 7 minutes. It is not something that you would need to be concerned about. But if you want to have Sierra Chart set your computer clock using the Network Time Protocol, then refer to the following: Network Time Protocol Client For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
