Date/Time: Tue, 15 Apr 2025 13:44:49 +0000
"sc.DrawStudyUnderneathMainPriceGraph = 1;" does not work
View Count: 55
[2025-04-04 09:37:34]
nixon - Posts: 7
I have already set sc.DrawStudyUnderneathMainPriceGraph = 1; to draw vertical lines.
But the lines still drawn over the candles.
[2025-04-04 10:26:44]
User431178 - Posts: 646
And how are you drawing the lines?
If you are using sc.UseTool, then you need to set s_UseTool::DrawUnderneathMainGraph accordingly.
Using Drawing Tools From an Advanced Custom Study: s_UseTool::DrawUnderneathMainGraph
